Results 1 to 10 of 10
Thread: Australian VX Commodore
    Apr 2008
    Default Australian VX Commodore
    Could somebody provide some help, please. I want to but a nice package to work on my Commodore VX 2002(Australia). I have downloaded the demo version V4 and have problems establishing coms, I think.
    I built a small circuit using a MAX 232 dual line TRX. I seems to work OK and it echos back any chars I send it. I tested it with my BERT up to 38400 with no errors.
    I connected it to pin 9 on the ODBC2 plug under the steering (used gnd and +12 v from there too).I get a steady flow of data on my serial analyser with the IGN off.
    I get data flow with the IGN on. I think there is something wrong with the
    serial data but don't know. At times I select a Macro to run and the DTC pane turns green and there are a number of items listed in it. They never seem to change.
    What I want is the dials page to work. I tried the other model Commodore XLM files but the software complained more about incorrect data headers.
    I have had a CRO on the data and it looks about right for TTL, swings right down to ground both ways and up to +5. Frequency looks close but haven't measured the bit width.
    The top of the screen is just clicking the green stop sign icon. Sometimes (without my understanding)it runs indefinitely usually just a second or so with "Com timeout expecting header frame".
    The green chatter icon and the one next to it both seem to display data.. I have noticed the engine fan and the Engine check lamp do go on, which seems to indicate some sort of communication on the ECU bus.
    I am really stuck and would appreciate any help.
    I have tested the car with a CARMA scantool and it work OK.
    I get with the green stop icon
    Start macros:Engine data
    Synchronizing ALDL comms....
    waiting for heartbeat:$08,$55$A3
    waiting for ALDL bus silence for 50 ms
    send: $f5,$57,$01,$01,$82
    comm timeout expecting header byte
    with Display chatter and Auto detect chatter I get loads of green data all byte of $(hex?) with the occassional "comm timeout expecting header byte"
    Graeme
    Try changing the Module ID from $F5 to $F7 for each of the three defined messages:
    1. ECM/PCM_$01
    2. ECM/PCM_$04
    3. ECM/PCM_$0A
    See image for the value to change.
    Apr 2008
    Default Still no running comms
    I check that variable you mentioned. It was set to $F5 I changed it to $F7, no change. I took the time to get some proper blocks of data. I ran tests with the ignition off then on then with the engine running. There seems to be some 2way comms but it halts after a few seconds. My Vx is from 200 not 2002 as i thought, if that makes any difference.
    Your help is appreciated!
    Thanks,
    Graeme
    Ignition OFF -run aldl
    40:05.312: Start macro: Engine data and DTCs: DATADTC
    40:05.328: Synchronising ALDL communications...
    40:05.328: Waiting for heartbeat: $08,$55,$A3
    40:05.328: Waiting for Aldl bus silence of at least 50ms...
    40:05.388: Start reading frame
    40:05.398: Aldl frame header byte: $11
    40:05.398: Aldl frame length byte: $5C
    40:05.413: Recv: $11,$5C,$00,$00,$0D,$00,$0B,$00,$00,$7B
    40:05.413: Finished reading frame
    40:05.413: Frame: 0 = $11,$5C,$00,$00,$0D,$00,$0B,$00,$00,$7B
    40:05.413: Start reading frame
    40:05.413: Aldl frame header byte: $ 8
    40:05.413: Aldl frame length byte: $55
    40:05.413: Recv: $08,$55,$A3
    40:05.413: Frame: 1 = $08,$55,$A3
    40:05.413: Found heartbeat: $08,$55,$A3 - ALDL synchronised
    40:05.413: Send suspend command: $F1,$56,$08,$B1
    40:05.413: Start writing frame
    40:05.413: Send: $F1,$56,$08,$B1
    40:05.413: Finished writing frame
    40:05.413: Wait 10 ms after writing, before reading...
    40:05.423: Start reading frame
    40:05.425: Aldl frame header byte: $F1
    40:05.425: Aldl frame length byte: $56
    40:05.425: Recv: $F1,$56,$08,$B1
    40:05.425: Finished reading frame
    40:05.425: MAX232 echo: $F1,$56,$08,$B1
    40:05.425: Wait 10 ms after writing, before reading...
    40:05.435: Start reading frame
    40:05.435: Aldl frame header byte: $F1
    40:05.435: Aldl frame length byte: $56
    40:05.435: Recv: $F1,$56,$08,$B1
    40:05.435: Finished reading frame
    40:05.435: Start writing frame
    40:05.435: Send: $F7,$57,$01,$01,$B0
    40:05.435: Finished writing frame
    40:05.435: Wait 10 ms after writing, before reading...
    40:05.445: Start reading frame
    40:05.446: Aldl frame header byte: $F7
    40:05.446: Aldl frame length byte: $57
    40:05.446: Recv: $F7,$57,$01,$01,$B0
    40:05.446: Finished reading frame
    40:05.446: MAX232 echo: $F7,$57,$01,$01,$B0
    40:05.446: Wait 10 ms after writing, before reading...
    40:05.456: Start reading frame
    40:05.560: Com timeout: Expecting frame header byte
    40:05.627: Aborting request due to previous error
    40:05.630: Start writing frame
    40:05.630: Send: $F7,$57,$01,$00,$B1
    40:05.630: Finished writing frame
    40:05.630: Wait 10 ms after writing, before reading...
    40:05.640: Start reading frame
    40:05.641: Aldl frame header byte: $F7
    40:05.641: Aldl frame length byte: $57
    40:05.641: Recv: $F7,$57,$01,$00,$B1
    40:05.641: Finished reading frame
    40:05.641: MAX232 echo: $F7,$57,$01,$00,$B1
    40:05.641: Wait 10 ms after writing, before reading...
    40:05.651: Start reading frame
    40:05.747: Com timeout: Expecting frame header byte
    40:05.775: Aborting request due to previous error
    40:05.777: Start writing frame
    40:05.777: Send: $F7,$57,$01,$00,$B1
    40:05.777: Finished writing frame
    40:05.777: Wait 10 ms after writing, before reading...
    40:05.787: Start reading frame
    40:05.788: Aldl frame header byte: $F7
    40:05.788: Aldl frame length byte: $57
    40:05.788: Recv: $F7,$57,$01,$00,$B1
    40:05.788: Finished reading frame
    40:05.788: MAX232 echo: $F7,$57,$01,$00,$B1
    40:05.788: Wait 10 ms after writing, before reading...
    40:05.798: Start reading frame
    40:05.904: Com timeout: Expecting frame header byte
    40:05.931: Aborting request due to previous error
    40:05.933: Resuming normal ALDL communications...
    40:05.933: Send resume command: $F1,$56,$09,$B0
    40:05.933: Start writing frame
    40:05.933: Send: $F1,$56,$09,$B0
    40:05.933: Finished writing frame
    40:05.933: Wait 10 ms after writing, before reading...
    40:05.943: Start reading frame
    40:05.945: Aldl frame header byte: $F1
    40:05.945: Aldl frame length byte: $56
    40:05.945: Recv: $F1,$56,$09,$B0
    40:05.945: Finished reading frame
    40:05.945: MAX232 echo: $F1,$56,$09,$B0
    40:05.945: Wait 10 ms after writing, before reading...
    40:05.955: Start reading frame
    40:05.955: Aldl frame header byte: $F1
    40:05.955: Aldl frame length byte: $56
    40:05.955: Recv: $F1,$56,$09,$B0
    40:05.955: Finished reading frame
    40:05.962: Stop macro: Engine data and DTCs: DATADTC
    Quote Originally Posted by GML-VX View Post
    If you had ignition off, then it probably won't work. You need ignition on to communicate with the engine controller.
    VT V6 uses ID $F5
    VX V6 uses ID $F7
    Model year 200 is probably a VT.
    What's the 4th digit of your VIN?
    Apr 2008
    Default I had the ignition ON.
    I tried with the ign off and on and with the engine running. Results were the similar. I will have to wait to get the VIN it was made in 2002 and sold as VX. I did try other files(VT etc).
    I could not attach all the data I had. Which would be the most helpful for working this problem out. I can send new datasets.
    Thanks again
    Graeme
    Apr 2008
    Default more details
    VIN = 6H8VXX69A1L674***
    I ran the test again being sure to have the IGN ON use VX xlm file
    14:07.481: Start macro: Engine data and DTCs: DATADTC
    14:07.484: Synchronising ALDL communications...
    14:07.484: Waiting for heartbeat: $08,$55,$A3
    14:07.484: Waiting for Aldl bus silence of at least 50ms...
    14:07.732: Start reading frame
    14:07.808: Aldl frame header byte: $40
    14:07.808: Aldl frame length byte: $58
    14:07.808: Recv: $40,$58,$DD,$49,$06,$3C
    14:07.808: Finished reading frame
    14:07.808: Frame: 0 = $40,$58,$DD,$49,$06,$3C
    14:07.808: Start reading frame
    14:07.808: Aldl frame header byte: $41
    14:07.808: Aldl frame length byte: $63
    14:07.831: Recv: $41,$63,$00,$00,$00,$6C,$4A,$00,$00,$70,$F8,$22,$0 0,$00,$10,$00,$0C
    14:07.831: Finished reading frame
    14:07.831: Frame: 1 = $41,$63,$00,$00,$00,$6C,$4A,$00,$00,$70,$F8,$22,$0 0,$00,$10,$00,$0C
    14:07.831: Start reading frame
    14:07.843: Aldl frame header byte: $A8
    14:07.844: Aldl frame length byte: $55
    14:07.844: Recv: $A8,$55,$03
    14:07.844: Finished reading frame
    14:07.844: Frame: 2 = $A8,$55,$03
    14:07.844: Start reading frame
    14:07.844: Aldl frame header byte: $A9
    14:07.844: Aldl frame length byte: $57
    14:07.844: Recv: $A9,$57,$00,$00,$00
    14:07.844: Frame: 3 = $A9,$57,$00,$00,$00
    14:07.861: Aldl frame header byte: $20
    14:07.861: Aldl frame length byte: $55
    14:07.861: Recv: $20,$55,$8B
    14:07.861: Finished reading frame
    14:07.861: Frame: 4 = $20,$55,$8B
    14:07.861: Start reading frame
    14:07.861: Aldl frame header byte: $21
    14:07.861: Aldl frame length byte: $58
    14:07.867: Recv: $21,$58,$BC,$22,$46,$63
    14:07.867: Finished reading frame
    14:07.867: Frame: 5 = $21,$58,$BC,$22,$46,$63
    14:07.867: Start reading frame
    14:07.876: Aldl frame header byte: $D8
    14:07.876: Aldl frame length byte: $55
    14:07.876: Recv: $D8,$55,$D3
    14:07.876: Finished reading frame
    14:07.876: Frame: 6 = $D8,$55,$D3
    14:07.876: Start reading frame
    14:07.896: Aldl frame header byte: $90
    14:07.896: Aldl frame length byte: $55
    14:07.896: Recv: $90,$55,$1B
    14:07.896: Finished reading frame
    14:07.896: Frame: 7 = $90,$55,$1B
    14:07.896: Start reading frame
    14:07.896: Aldl frame header byte: $91
    14:07.896: Aldl frame length byte: $58
    14:07.902: Recv: $91,$58,$18,$00,$00,$FF
    14:07.902: Finished reading frame
    14:07.902: Frame: 8 = $91,$58,$18,$00,$00,$FF
    14:07.902: Start reading frame
    14:07.914: Aldl frame header byte: $A0
    14:07.914: Aldl frame length byte: $55
    14:07.914: Recv: $A0,$55,$0B
    14:07.914: Finished reading frame
    14:07.914: Frame: 9 = $A0,$55,$0B
    14:07.914: Start reading frame
    14:07.914: Aldl frame header byte: $A1
    14:07.914: Aldl frame length byte: $57
    14:07.914: Recv: $A1,$57,$08,$00,$00
    14:07.915: Frame: 10 = $A1,$57,$08,$00,$00
    14:07.915: Start reading frame
    14:07.929: Aldl frame header byte: $11
    14:07.929: Aldl frame length byte: $5C
    14:07.943: Recv: $11,$5C,$FF,$00,$4D,$00,$00,$00,$00,$47
    14:07.943: Finished reading frame
    14:07.943: Frame: 11 = $11,$5C,$FF,$00,$4D,$00,$00,$00,$00,$47
    14:07.943: Start reading frame
    14:07.943: Aldl frame header byte: $40
    14:07.943: Aldl frame length byte: $58
    14:07.943: Recv: $40,$58,$DD,$49,$06,$3C
    14:07.943: Frame: 12 = $40,$58,$DD,$49,$06,$3C
    14:07.954: Aldl frame header byte: $41
    14:07.954: Aldl frame length byte: $63
    14:07.970: Recv: $41,$63,$00,$00,$00,$6C,$4A,$00,$00,$70,$F8,$22,$0 0,$00,$10,$00,$0C
    14:07.970: Finished reading frame
    14:07.970: Frame: 13 = $41,$63,$00,$00,$00,$6C,$4A,$00,$00,$70,$F8,$22,$0 0,$00,$10,$00,$0C
    14:07.970: Start reading frame
    14:07.979: Aldl frame header byte: $ 8
    14:07.979: Aldl frame length byte: $55
    14:07.979: Recv: $08,$55,$A3
    14:07.979: Finished reading frame
    14:07.979: Frame: 14 = $08,$55,$A3
    14:07.979: Found heartbeat: $08,$55,$A3 - ALDL synchronised
    14:07.979: Send suspend command: $F1,$56,$08,$B1
    14:07.979: Start writing frame
    14:07.979: Send: $F1,$56,$08,$B1
    14:07.979: Finished writing frame
    14:07.979: Wait 10 ms after writing, before reading...
    14:07.989: Start reading frame
    14:07.990: Aldl frame header byte: $F1
    14:07.990: Aldl frame length byte: $56
    14:07.990: Recv: $F1,$56,$08,$B1
    14:07.990: Finished reading frame
    14:07.991: MAX232 echo: $F1,$56,$08,$B1
    14:07.991: Wait 10 ms after writing, before reading...
    14:08.001: Start reading frame
    14:08.001: Aldl frame header byte: $F1
    14:08.001: Aldl frame length byte: $56
    14:08.001: Recv: $F1,$56,$08,$B1
    14:08.001: Finished reading frame
    14:08.001: Start writing frame
    14:08.001: Send: $F5,$57,$01,$01,$B2
    14:08.001: Finished writing frame
    14:08.001: Wait 10 ms after writing, before reading...
    14:08.011: Start reading frame
    14:08.012: Aldl frame header byte: $F5
    14:08.012: Aldl frame length byte: $57
    14:08.012: Recv: $F5,$57,$01,$01,$B2
    14:08.012: Finished reading frame
    14:08.012: MAX232 echo: $F5,$57,$01,$01,$B2
    14:08.012: Wait 10 ms after writing, before reading...
    14:08.022: Start reading frame
    14:08.122: Com timeout: Expecting frame header byte
    14:08.513: Aborting request due to previous error
    14:08.518: Start writing frame
    14:08.518: Send: $F5,$57,$01,$00,$B3
    14:08.518: Finished writing frame
    14:08.518: Wait 10 ms after writing, before reading...
    14:08.528: Start reading frame
    14:08.529: Aldl frame header byte: $F5
    14:08.529: Aldl frame length byte: $57
    14:08.529: Recv: $F5,$57,$01,$00,$B3
    14:08.529: Finished reading frame
    14:08.529: MAX232 echo: $F5,$57,$01,$00,$B3
    14:08.529: Wait 10 ms after writing, before reading...
    14:08.539: Start reading frame
    14:08.638: Com timeout: Expecting frame header byte
    14:08.665: Aborting request due to previous error
    14:08.667: Start writing frame
    14:08.667: Send: $F5,$57,$01,$00,$B3
    14:08.667: Finished writing frame
    14:08.667: Wait 10 ms after writing, before reading...
    14:08.677: Start reading frame
    14:08.678: Aldl frame header byte: $F5
    14:08.678: Aldl frame length byte: $57
    14:08.678: Recv: $F5,$57,$01,$00,$B3
    14:08.678: Finished reading frame
    14:08.678: MAX232 echo: $F5,$57,$01,$00,$B3
    14:08.678: Wait 10 ms after writing, before reading...
    14:08.688: Start reading frame
    14:08.794: Com timeout: Expecting frame header byte
    14:08.821: Aborting request due to previous error
    14:08.824: Resuming normal ALDL communications...
    14:08.824: Send resume command: $F1,$56,$09,$B0
    14:08.824: Start writing frame
    14:08.824: Send: $F1,$56,$09,$B0
    14:08.824: Finished writing frame
    14:08.824: Wait 10 ms after writing, before reading...
    14:08.834: Start reading frame
    14:08.835: Aldl frame header byte: $F1
    14:08.835: Aldl frame length byte: $56
    14:08.835: Recv: $F1,$56,$09,$B0
    14:08.835: Finished reading frame
    14:08.835: MAX232 echo: $F1,$56,$09,$B0
    14:08.835: Wait 10 ms after writing, before reading...
    14:08.845: Start reading frame
    14:08.845: Aldl frame header byte: $F1
    14:08.845: Aldl frame length byte: $56
    14:08.845: Recv: $F1,$56,$09,$B0
    14:08.845: Finished reading frame
    14:08.853: Stop macro: Engine data and DTCs: DATADTC
    Apr 2008
    Default A bit more sucess
    I have managed to get some coms going. I made some changes to the interface to improve the HF response and it started to work!.
    I used the VX XML file with $F7 as the ID in the macro.
    Thanks for your help.
    One thing still not quite sure of is the DTC codes.
    I select the Macro and it seems to run. the DTC engine icon on the top of the pane goes green. And the icon list appears
    The icons on that page that are always green (engines). They are not a complete list of the DTC and never change. I know they are not the DTC codes from checking it with a scanner
    What I see is:
    RH O2 missing CEL(what is CEL?) True etc
    ECT high True
    ECT low True
    ECT unstable True
    ECT circuit False
    Linear EGR flow check False
    TPS stuck False
    TPS high True
    Makes no sense. The ALDL and dashboard panes run OK.
    Any tips?
    Seems to be a great program. What did you write it in. Not planning to release the source?
    Is there a combination license for V5 and the later Vs for ODB2?
    Graeme
    Glad you figured that out - I would not have been much help with that.
    Any tips?
    The DTCs are limited to only displaying the first 8 in Eval mode.
    All DTCs are listed, the SET DTCs will be displayed with a red icon.
    See the user manual: "Relaese Notes -> Pro vs Eval" section to see the differences between Pro and Eval versions.
    Thanks, although it is fairly primitive compared to the current V7 software for OBDII. It's written in Delphi (so is EFILive V7). No plans to release the source.
    No
  1. VX and VY commodore
    By Thumper in forum Gen III V8 Specific
    Last Post: February 8th, 2009, 11:48 AM
  2. Australian Daewoo Lanos 1999 Strange Data
    By leibhold in forum EFILive V4
    Last Post: November 25th, 2008, 12:40 AM
  3. Australian Visa
    By caver in forum Lounge
    Last Post: June 7th, 2007, 09:10 AM
  4. Australian LS1 Alternators
    By Biggsy in forum Lounge
    Last Post: March 4th, 2007, 02:36 AM
  5. A Simple Question For You Australian Guys...
    By DramaFoYoMama in forum Lounge
    Last Post: January 19th, 2006, 10:40 AM
