Results 1 to 10 of 12
Thread: cant upgrade to COS3
    Feb 2008
    Default cant upgrade to COS3
    When trying to do a full reflash of the COS i get an error, and it reports pcm is unknown stat.e It also says " cannot create file C:\programfiles\efilive\v7.5\Configuration\PCMLock s.ini access is denied. Its done this several times now. Thanks for any help. OS #12587603 COS#04073003
    If you're running Windows Vista, it may be that you need to have administrator privileges.
    Feb 2008
    Hmm, I will look into it. Im the only user on this vista computer so my account should have full privledges. I dont have problems with anything else tho.
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Quote Originally Posted by charcold-bowtie View Post
    You will have to run it as administrator OR you can give the whole efilive dir administrator rights.
    Feb 2008
    Hmm. i looked it up and im the admin on the computer. Any other ideas, it still wouldnt work and reported the same error. Thanks for any help.
    Nov 2006
    Right click on the Tune Tool icon and click "Run as Administrator", then click "Allow". I used to have the exact same problem and this would fix it but I got sick of doing it everytime so I gave premissions to the EFILive dir that "EVERYONE" can write to it.
    Vista doesnt let you run as Administrator all the time, even if you have only one account. Its is part of its new security features and User Access Control aka PITA ( Pain In The Arse )
    Jez
    UAC, first thing I turned off as Im the only user on my laptop. Dang UAC gets on my nerves the second I work on a friends PC, hate it with a passion.
    Feb 2008
    O, i was unaware that it would still block some things. Thanks for the input guys will try it again later. Ive only had this vista computerfor about a month...
    Jun 2008
    Thank god for this thread! I was getting the same error and was getting frustrated, then I remembered reading this and ran the program as administrator and I'm now running on COS3.
    Gunnar, welcome...
  1. M6 to 60e swap with COS3 & SD
    By 2ktransam in forum Custom Operating Systems
    Last Post: June 22nd, 2009, 09:13 AM
  2. Help with cos3
    By EVODRIFTER in forum Custom Operating Systems
    Last Post: November 2nd, 2008, 03:50 PM
  3. Cos3 (2bar)
    By aaronr in forum Custom Operating Systems
    Last Post: October 1st, 2008, 09:15 AM
  4. IS COS3 for SD only?
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: September 30th, 2008, 01:48 PM
  5. V2 Cos3
    By Chevy366 in forum FlashScan V2
    Last Post: April 20th, 2007, 10:12 AM
