Thread: tune help
    Feb 2008
    Default tune help
    finally got the truck moved over to COS3. BUt im still having WOT rich problems. The VE table isnt perfect in all area yet. The truck runs at 10-1 AFR at WOT. Other than that it is fine. CAn any one see anything in the tune that looks funny. Thanks for any help. The truck is a full bolt on cammed 4.8 liter. I was told that my VE looked funnyand i know it does i jsut dont know why. Perhaps it suggest a vaccuum leak. I also had trouble with a vaccuum leak on an injector swap a few weeks ago.
    Jan 2007
    man how do you fill all those cells? I can't really get anything over 4kish in the low load cells...
    Oct 2006
    Can you post the log for that screenshot. With your Bens around 2% at wot the only way you will be getting an AFR of 10 to 1 is if it is commanded. You still have B0701 cat convertor protection enabled. This may be the culprit.
    The Tremor at AIR
    Feb 2008
    Well yes i can. The tune this velog is from is a stock OS tune. The tune in the first post is mr current sd tune. Also the log will be attached. thanks for anything ive been fightin this crap for weeks and my eyes bleed for research haha. I usuall cant keep it off the low load high rpm cells. Look at the log at the cell #'s. this is my new intended tune for auto ve in COS3 but its way lean, 20-1 for some reason.
    Oct 2006
    Change your B3647 table to 14.5 in the low map areas & enrichen in the high map areas. You may not be far enough away from stoich to prevent STFT from occuring. Turn off cat protection & then see how that goes. Make sure you restart from a stock VE table with about a 5% increase.
    The Tremor at AIR
    Feb 2008
    Cool thanks. I will try all of the above. I was unaware of the stft might still have an effect. I was under the impression that as long as it wasnt that specific value, they wouldnt intervene.
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    Last Post: August 4th, 2008, 08:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
