Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 122
Thread: BB Logging beta update: April 26, 2008
  1. #11
    Oct 2006
    Keep getting this error when I unzip and update for BBL , then open EFILive Explorer :
    I just click o-k , anything to this ?
    2006 Trailblazer
  2. #12
    With the address shown in the dialog box, I can track down the source of the fault. Once I find it I'll let you know what is causing it and whether it will affect any further operation of the software.
  3. #13
    Jul 2007
    Default Access Violation Errors
    First up, thanks heaps for the firmware fix. Great effort as usual!
    I've been getting these off and on for that last couple of releases but had put them down to the work laptop image and / or my use of the laptop. I tend to you the "sleep" function heavily and only reboot if there is a Windows update or I start seeing problems like slow downs or the above mentioned "access violations". I have received these errors from the Hapi driver when connecting the V2, from the Tune tool when saving files and the scan tool at various times. From now on I'll note the addresses and pass them through.
    Simon
  4. #14
    Quote Originally Posted by tunedbyGM View Post
    Clicking ok is ok. It is caused when EFILive_Explorer is attempting to load the settings from a previous session. I.e. trying to display the last used folder etc.
    The second time you run the software it should be ok.
  5. #15
    Quote Originally Posted by swingtan View Post
    Simon
    Thanks, that will help. Also documenting the steps leading up to any error will help more so.
  6. #16
    Lifetime Member Kevin Doe's Avatar
    Aug 2007
    I changed the return codes from the write() function to allow the file system stats to be collected. But failed to update the code that writes the meta data.
    Attached firmware update should fix that.
    Did you edit the .zip file in your first post to include the new firmware file?
  7. #17
    Quote Originally Posted by Kevin Doe View Post
    No, not yet. It will be V2.05.18 when I do.
  8. #18
    Aug 2007
    I thought I should chime in. This is the first firmware and boot block I have had problems with. I first updated my v7x and v8 folders. Then started EFILive Explorer. I got the Access Violation. Second start attempt worked fine. I flashed the new boot block and it stuck in dead poll. Couldnt update the bootblock or firmware. The good news it, I went back to the 0414 EFILive Explorer, and reflashed that bootblock successfully. Then successfully flashed back to the 0414 firmware. Now it works fine. Tried the 0426 again and same errors. Went back to 0414 again and all is good. Mucho problems with this one looks like. Any logs you need or want to see, Paul?
    2002 WS6, All-Lunati 383 Strok'r @11:1, Cartek Heads, Keith/Ross Racing Custom Cam, Victor Jr., 492whp 457wtq,
    Cartek Clutch, 9" Moser w/4.11's, 35 spline Detroit Locker, QA1's, NX, BMR, Tuned w/ EFILive V2 Black Box Logging
    Check Out My Latest Tune File: HERE
  9. #19
    Aug 2007
    UPDATE: I used the 0414 EFILiveExplorer to flash the 0427 bootblock and firmware and now it seems to woork fine with the latest version. At least the version numbers in 'Explorer show it is current.. and I have the Inverse feature. Weirdness. All is good now I will try BBL in the morning.
  10. #20
    Senior Member Hyper99's Avatar
    Oct 2005
    Had the same problem with the Exeption Error
    Noticed that when programming the firmware, EFI Explorer used to give a percent of completion. Mine just sat there, and finally said complete......Strange.....Hope it works tomorrow.
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
  1. BB Logging beta update: May 19, 2008
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 12, 2008
    Last Post: May 27th, 2008, 09:01 AM
  3. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: April 07, 2008
    Last Post: April 14th, 2008, 10:31 AM
