Results 1 to 3 of 3
Thread: LMM Speedo Calculator
    Default LMM Speedo Calculator
    I am trying to adjust a speedo for larger tires. I tried using the speedo calculator and it didn't seem to work. Is there an issue with the LMM's or am I going about it the wrong way?
    Using the calculator for comparing two tires sizes showed a .55% correction. Very small and the truck is only off 2-3 mph to the low side.
    I adjusted the revs per mile and I think it narrowed it down from 5 mph off. Is this correct?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Hi Howard,
    There were some errors fixed with the speedo calculator in the latest Black Box logging beta release. I recommend using that software to calculate the new speedo values.
    After downloading the software, search the Release Notes pdf file for "speedo". It will show you the fixes that were made to the speedo.
    Good to know. I think I'll hold off until the stable release as everything has been working good. I think if I just fool with the REVS per MILE I'll get it done. We looked up the new tires R/P/M and will change that in that parameter.
    Howard
    1-954-703-5560
  1. Speedo-Calculator ?
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: April 3rd, 2014, 10:32 AM
  2. problems with the speedo calculator
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: December 19th, 2008, 10:34 AM
  3. need help with SPEEDO CALCULATOR
    By Boost in forum General (Diesel)
    Last Post: October 17th, 2007, 01:09 PM
  4. Speedo Calculator issues...Help Please
    By KAZ MotorSports in forum FlashScan V2
    Last Post: June 11th, 2007, 05:44 PM
