I just did the software/firmware/boot block upgrade and I am trying to use BBL to log my E38 PCM 06 GTO. I can select the pids in the V2 unit fine, but when I tell it to start logging I get an error:
Node: ECM
PID: AFRATIO_M is not supported, please de-select it.
I now have bootblock v 2.5.08 and firmware v 2.5.17
Ideas?
***EDIT - nevermind, I'm using an E40 PCM, not an E38. It works once I have the correct ECM selected.
