Hello I was wanting to know if any one here can tune a transmission for me. I have a 99 4l60e and have put a new engine in with greater horsepower. I am having the trans rebuilt and would like a better shift.. thanks for any help..
Basically bump the line pressures by ~10%, lower shift times, remove torque management, and adjust TCC lockup to your preferences. Thats about all Ive done with my 02 4L60E except add a Vette 1-2 servo.
Post your tune up man and Ill make some changes to it. I can point you in the right direction, but you are going to have to fine tune it for sure. Stock you are making a lot more hp/tq than I am, so while I can run 0 TM and 0 shift times, doing that on a stock 4L60E in a TA is probably a bad idea.
i just put in a stage 2 4l60E in the car and its supposed to handle up to 550 hp and 600 lbs trq and i know im not running anywhere near that right now but im not too scared of hurting this transmission i am on a different computer right now i will upload my tune as soon as i get back to washington. should be here in a week.
Yea post your tune and several guys would be willing to help..
heres the latest tune and the only thing i cant figure out is the torque reduction in the engine part of the tune i dont know where i should be setting this. im pretty sure that i got all of torque management all deleted out. thanks
and i have one more problem i was wondering how i would change the kickdown from 2 to 1 to still be able to kick down at 35 mph i can do it manually i just want it to do it without hitting the shifter maybe even a little more than 35 i dont remember how far 1st really goes.
You can log a certain PID to see if TM is still active..
Im lookin for it right now.
Ok for your Downshift.. look at D0925... Set that to your desired MPH.
What you can do is record a log from a dead stop and go wide open.. Look at what MPH your shifting 1-2... you can subtract 10-12ish from that and enter that into D0925...
