Results 1 to 5 of 5
Thread: Programming Silver PCM from 2001 S-10 4.3L to handle 97 Vortec
    Apr 2008
    Default Programming Silver PCM from 2001 S-10 4.3L to handle 97 Vortec
    I have a semi difficult question for anyone. the 97 Tahoe that has the 5.7L engine in it which i believe has the 0441 "black box" computer. i currently have the 2001 s-10 that has the silver 2 (red and blue) connector and am wondering if i can use any map on my pcm so i am able to run my engine. I dont currently own the efilive but am wanting to buy one if i can resolve this problem through you guys. Any help would be great. Thanks
    Apr 2008
    also, which version of the EfiLive will i need to purchase to fulfill this. Thanks
    Feb 2006
    Either EFI live tuning tool will work on your S10. For $200 extra I would opt for the V2. Is your intention to install a 1997 Vortec V8 or V6?
    Al
    Apr 2008
    yes, the vortec engine is from a 97 with the poppet style intake. i am just wondering which map i can load into my computer so i can run that style v8. is there an LS program i can run that will accomplish this?
    Sep 2007
    You need to pick up a base Express van tune from '01 or '02 to run that engine with that PCM. Those were the only Vortec 5.7 V8 engines that ran on the '411 PCM.
  1. Err 1400, Invalid Window Handle
    By Mr. P. in forum Do you want to be a Beta Tester?
    Last Post: December 20th, 2009, 02:12 PM
  2. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 05:49 AM
  3. HELP PLEASE!!! Error programming Vortec V6 4.3
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: September 17th, 2008, 09:55 AM
  4. 2001 Silverado 4x4 LM7 Vortec with Whipple & 42lb injectors
    By bratch in forum Vortec V6/V8 Specific
    Last Post: April 1st, 2007, 04:28 PM
