Results 1 to 4 of 4
Thread: Locking up in Vista
    Apr 2008
    Default Locking up in Vista
    Anybody have any experience with the computer (Dell laptop with Vista, plenty of resources) just completely freezing up during data logging. The screen just freezes with the pointer completely immobilized. ALT-CTRL-DEL does not give Task Manager, nothing. Only solution is to restart by holding the power button down, losing all logged information.
    There seems to be no pattern in this process. I have been successful with two data logging sessions. Sometimes the lock occurs seconds after starting logging, sometimes longer, several minutes.
    All latest drivers and versions installed ( EFILiveV7_5_3_Setup_Files.zip, FlashScan D2XX USB drivers V2.02.04 for Win2K, WinXP and Vista).
    Not happy.
    Dan, welcome to the forum...
    I pm'd Tech Support.
    Apr 2008
    Thank You!
    Any conflicts from maintenance programs, registry edits, etc..... that I could resolve?
    --dan
    There is a known bug that will cause exactly what you describe if you start logging with 0 channels of PID data selected. The computer will hang as soon as you click the start recording button.
    I.e. you must have at least one PID selected with a channel count of greater than 0.
    However, I do not know what would cause that problem once a log has started.
  1. TCC Locking
    By GMPX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2009, 08:22 PM
  2. Locking ecm
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 19th, 2007, 02:10 PM
