Results 1 to 3 of 3
Thread: LB7/LLY Allison DVT
    Default LB7/LLY Allison DVT
    Ross, would it be possible to add a "Hold 6th" button to the LB7/LLY Allison DVT for those that have the Suncoast 6 speed upgrade? For those that don't have it, and have a 5 speed TCM & VB, I suspect one of two outcomes if one tried to use it: Either the TCM would yak on the command and not do anything with it, or it would accept the command and the transmission would drop to Neutral and probably give a "Shift Range Inhibited" (I've had this hapen several times with the A40 in my truck).
    I'm not sure it's actually a valid combination the TCM will accept. Although the gear selection is defined in one byte so it could accept a value of 6th it might not happen.
    I can send you a .dvt if you have a truck you can test it on.
    PM Sent
    On the subject of DVT, are there any plans to implement it as a standalone function?
    Also, does the "Clear all adapts to fast" function ONLY set the TCM to fastlearn and not clear taps (like it appears)?
  1. Allison DVT's
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: October 17th, 2009, 03:36 PM
