Results 1 to 7 of 7
Thread: Is 7.2.3 going to have more MAPS?
    Nov 2003
    Default Is 7.2.3 going to have more MAPS?
    Is 7.2.3 going to have more MAPS? I was setting up my maps and I am one short. I need 11 but only have 10?
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Default Re: Is 7.2.3 going to have more MAPS?
    Quote Originally Posted by BowlingSS
    Bill
    There is no technical reason why there cannot be more maps, but V7.2.3 will still only have 10. And I thought 10 was overkill.
    Lifetime Member Steve Bryant's Avatar
    Feb 2004
    Bill,
    What are you tracking with 11 maps? Do you think that you will really use them in the course of a week or two?
    I've done a fair amount of logging and tuning in the last year and I only use about three maps on a rregular basis. Although I have set up about 15 for use, I only display the following:
    WBAFR - MAP Versus RPM (used to set VE in Speed Density Operation)
    WBAFR - MAF Versus Freq (used to adjust MAF Calibration)
    KR - RPM Versus Cyl Air (used for High Octane Spark Calibration)
    All my best,
    Steve
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Ten is definitely not overkill; 24 would be one of the sweet spots due to the number of PIDs one can record at high speed.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    10 is not overkill; I use maps a lot to see if there's patterns between various parameters.
    3 dash pages also is not enough, but maybe that's just me.
    I was asking Paul about this today from the point that having more MAP's slows the PC down, Paul said it did......this made me think I need to tell you something I noticed on my PC.
    If I am running off mains power it runs at 2.4GHz, if off battery it runs at half that......not sure how 1.2GHz would go replotting 24 maps, especially as Paul told me today he might just have one more trick up he's sleeve with the maps
    Maybe there needs to be Properties options that say "Number of Maps" and "Number of Dash Pages"; people who don't use many maps at once could then set the Number of Maps low and have minimal slowdown.
  1. Maps
    By limited cv8r in forum EFILive V4
    Last Post: August 6th, 2007, 09:26 AM
  2. hp and tq maps
    By southern in forum General (Petrol, Gas, Ethanol)
    Last Post: July 5th, 2007, 04:10 PM
  3. 7.4 maps
    Last Post: April 1st, 2007, 06:33 PM
  4. Maps
    By Josho in forum Gen III V8 Specific
    Last Post: January 3rd, 2007, 02:39 AM
  5. AFR MAPS
    By Tordne in forum General
    Last Post: May 6th, 2005, 03:28 PM
