I pm'd tech support.
Rob, is also calling them Thanks!
Please run the Scan Tool software, and if/when that message appears, please save the error report that is displayed or if no error report is displayed, please manually generate one using the menu option: File->Generate error report. Save the report and email it to me at paul@efilive.com. Please include a link to this thread in your email.
I was finally able to do a "dead Poll" and got this info. Firmware 2.04.70, Boot Block 2.04.10, When I click (about) it say's V2.04.04 build (35). Does anything here look wrong? i'll get an error report # to you, it has not given me one yet. I just get the blue box with the above message. and then when I click OK, I get another box that says "Lost connection".
After you close the dialog box that says: "Lost connection", please manually generate an error report using the menu option: File->Generate error report.
Then send it to me at paul@efilive.com
E-mail sent!
I just got my new EFILive and I have the same syptoms... Mine is the build 36 where his was 35. FW is 2.04.70 and BB is 2.04.10.
What was the fix?
Roger
Upgrade to this release:
http://forum.efilive.com/showthread.php?t=8289
You should upgrade your V2 firmware from V2.04.70 to V2.04.72 using the FlashScan Firmware programming software), then perform the boot block upgrade process (to V2.05.08) from the menu on your FlashScan device.
Then program in the latest V2.05.17(0612) firmware using the V8.1 EFILive_Explorer program.
More details in the Readme.rtf file that is part of the V8.1 install.
I had Guy help me load V7.5.4 with FW 2.04.72 and I am up and playing!!!!
Not near as hard to transfer as I thought.
Thanks for the help and the great product!
Roger
