Results 1 to 3 of 3
Thread: Changing usb cable on FSV2
    Feb 2005
    Default Changing usb cable on FSV2
    High all, i just changed the USB cable, the old one had a few too many km's on it lol!
    ever since the change, i have logging and flashing issues, particularly with the e38 pcm.
    when i log the e38, a few minutes later the logging stops, then the "abort" message comes up.the logging is also VERY slow, and i have lost the cursor, ie: i cannot use the mouse to select certain logged data, i have to use the arrow buttons.
    when i try to flash the e38, an error message comes up saying, either bootloader rejected or cannot comunicate with pcm check cable connection etc etc.
    if i disconnect the obd cable then reconnect and try to reflash all works fine.
    it may be a coincidence, but the day i changed the usb cable is the same day i updated to the latest bbl software.
    do you think its the cable or the update?
    Mar 2004
    are you running 26 4 update from this post & loaded the 27 4 update from the 5th post
    http://forum.efilive.com/showthread.php?t=7905
    Quote Originally Posted by AGRO View Post
    Try pressing F2 which toggles mouse control of the chart inspector on and off.
    I don't think it will be the cable.
    As NTAE asked are you using the very latest bet software?
  1. Changing OS
    By lownslo in forum Gen III V8 Specific
    Last Post: October 30th, 2009, 04:40 AM
  2. Changing BEN map from AFR to ?
    By ssvolvo in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2008, 06:48 AM
  3. Changing IFR
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2006, 06:40 AM
  4. changing from F to C
    By batesyellow01 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2006, 08:28 AM
  5. changing ecm
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 03:19 PM
