Can a person flash a new ECM with a toon file with the same OS?
The ECM was stolen and I had to buy a new one.
Should absolutely be possible. With most ECMs you can also perform a full flash and change the base OS.
How does one have their ECM stolen?
Andrew
EFILive Crew
The car was wrecked and was bought from copart. Do I flash it and then do a vin change and then a vats relearn?
This is a ZO6
Mark, this is how I did it: showthread.php?t=5958
Joe
It is telling me that it is a loss of comunication with the ECM.
Are you using FlashScan V1 or V2...?
Which version and build (do Help->About)...?
Which PCM (does it have a label showing service number or part number)...?
I am using V2 . service # is 12597121. Gen-IV V8
It says it during test
u should be able to
01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
