I'm looking for an E38 standard file for a VE manual L98 as I have a conversion vehicle with an auto program causing issues with electronic throttle that I think is related to the absence of the tans ECU.
Cheers
Joel
Cheers
Joel
try this one
Thanks I'll give it a go Monday, it's a different callibration to the L76 ECU I have from a VZ Auto. I'm hoping it will reflash as the throttle module data should be the same being the engines are so close in design.
Cheers
Interesting, no spark with the L98 tune. I found the LQ9 calaibration seems to work, I haven't looked into the why though.
Thanks for the help
Joel
Got an L76 manual tune from Steve at OZtrack and no problems, came up with the requester that Calibrations bootblock different, did a full flash with the bootblock bypass with toes and fingers crossed and all was well.
Thanks Steve
