Originally Posted by
JoshH
Well, I think there are still a few bugs in the 6 speed DVT. If you have the DVT enabled it seems to work fine. Then when you deactivate it it drops into neutral, bangs real hard, and throws up a "Shift Range Inhibited" message on the DIC.
Also, I was at the Diesel Power Challenge with IdahoRob this week. We were using the DVT feature on EFILive to lock the converter and hold the truck in 5th gear. We started the dyno pull at around 1500 RPM. It got up to somewhere around 2500 and all of a sudden it jumped into neutral and the "Shift Range Inhibited" message popped up again.
I'm also still having the reverse issue when my trans is warm, but I'm not 100% sure that is because of DVT.
