Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Allison 6speed Range inhibit after DVT
  1. #11
    Feb 2007
    Quote Originally Posted by JoshH View Post
    Well, I think there are still a few bugs in the 6 speed DVT. If you have the DVT enabled it seems to work fine. Then when you deactivate it it drops into neutral, bangs real hard, and throws up a "Shift Range Inhibited" message on the DIC.
    Also, I was at the Diesel Power Challenge with IdahoRob this week. We were using the DVT feature on EFILive to lock the converter and hold the truck in 5th gear. We started the dyno pull at around 1500 RPM. It got up to somewhere around 2500 and all of a sudden it jumped into neutral and the "Shift Range Inhibited" message popped up again.
    Do you guys have any idea about what's going on here? Is there anything I can do to help get it figured out?
  2. #12
    Josh, just by chance when you deactivate the bi-di controls, are any of the overrides still enabled? I'm just trying to get my head around a possible process error, in other words if you deactivate the bi-di controls before disabling the individual control this might cause a problem (it shouldn't, but who knows!). If that is actually the cause then we need to address that to happen automatically.
    Meanwhile I will endeavour to get a number of the PID's in the scantool that will help show us why the shift inhibit came up. Also, thanks for your assistance and patience on getting the DVT's working for the 6 speed. I always seems so odd that some trucks seems to play nice whilst others don't. Just out of interest, have you used a TechII for bi-di on the truck recently?
  3. #13
    Feb 2007
    Nope, I disabled each individual control, and then disabled the whole thing (the enable/disable buttons next to the drop down menu).
    Nope, no Tech II hooked up to my truck for a while. I'll keep an eye on everything to see when you get a new update out. Thanks.
  4. #14
    Jan 2008
    Hey this was happening to me too. I tried this in 4th gear with the tcc locked and just about the same rpm range it popped out into neutral with the DIC message.
  1. '06 6speed tuning inconsistancies
    By bballer182 in forum Allison 5 & 6 Speed
    Last Post: December 10th, 2009, 06:42 AM
  2. LTFT - range vs + range lean rich question
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 14th, 2009, 06:18 AM
  3. Need a 2006 Corvette 6speed auto file.
    By John02SS in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2009, 02:16 AM
  4. afr thru out rev range...
    By brokenfly in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2007, 01:56 PM
