The engine is a 5.7L Vortec bored .030 over with an eagle stroker assembly, ported and polished vortec 64cc heads, ported Mercruiser marine efi intake with 29lb injectors, ported throttle body, msd 6al ignition, .550 lift beehive springs, crane aluminum roller rockers 1.5 ratio, comp cam 08-467-8: Lift: .576"/.570" w/1.6 Rockers Duration: 280°/288° RPM Range: 2000-6000
Does anyone have a map that i can use as a starting point for my tunung for this engine in my 2001 s-10 with the 0411 pcm? Any help would be great, thanks
