Does anyone know that if you Change your cylinder volume to a higher setting but havent changed the bore of the engine if it will give you a higher compression without hurting anything. That and any ideas on what is the max spark advance able at an idle and from and idle to WOT. (i.e. trying to make more low end torque)
