Page 8 of 8 FirstFirst ... 678
Results 71 to 78 of 78
Thread: Which wideband are you using w/EFI Live?
  1. #71
    Senior Member thunder550's Avatar
    What other widebands have you guys gotten to work on the V2 serial input? My LC-1's serial connection works intermittently (this is my second unit - first one quit working altogether) and I'm sick of dealing with it. I can't get Logworks, LM programmer, or EFILive to see the serial signal today, but it worked yesterday, but not the day before, etc. I also get "heater circuit open" errors about once every 3-4 startups. If I cycle power it comes back on fine. I hate this thing.
  2. #72
    May 2007
    I was having the same issue with my lm1 and just bought a new sensor yesterday . It works great now, sounds like your sensor is getting bad.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  3. #73
    Did that fix your serial connection problem as well?
  4. #74
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Got a PLX and TechEdge both working serial flawlessly with the V2. The thing i love about serial is I dont have change any PIDs etc. WBO2AFR is the same on every serial wideband. Love it
  5. #75
    Thanks for the info. I'll look into one of those.
    **edit - just bought a PLX unit. Looks to be much easier to install than the Innovate, and since I got the digital gauge with it I can do away with ALL of the analog outputs. I have always had ground offset issues. No more
  6. #76
    Jul 2008
    I am using TechEdge 2J1 works fine.
  7. #77
    Jul 2007
    Quote Originally Posted by thunder550 View Post
    Just curious how old your LC1 is so I know what I have to look forward to. Mine is about 1 month and so far, so good w/serial connection.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
  8. #78
    Junior Member boyley's Avatar
    Jul 2008
    I havent installed it yet but I've purchased the PLX DM-100 + SM-AFR
  1. What wideband do you use with EFI Live???
    By Chuck CoW in forum General (Petrol, Gas, Ethanol)
    Last Post: December 23rd, 2011, 10:53 AM
  2. New to efi live / wideband question
    By Toby Van Horn in forum Gen III V8 Specific
    Last Post: November 22nd, 2009, 09:06 AM
  3. Please Help.. EFI Live-Adding Wideband PID
    By tatasta in forum Gen III V8 Specific
    Last Post: April 8th, 2009, 02:10 PM
  4. EFI live won't see wideband...???
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: July 15th, 2008, 03:37 AM
  5. wideband and efi live
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: May 25th, 2006, 04:28 PM
