Thread: Massive log numbers???
    Jan 2007
    Default Massive log numbers???
    Just curious.
    How many logs have the rest of you guys run...and when will you be happy with your tune?
    I just counted the logs I have stored in my 7.5 folder (so not counting those in 7.0) and I have run 735 as of this morning (that's all just on my Truck).
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jul 2007
    I have 250 just for my car and I only started just before Christmas. If I include the other cars I've logged it's more like 400. I still have a way to go to catch you, but I think you'll find a few of the tuning shops may have a few more
    Simon.
    Jan 2007
    Yeah...I should have specified for one/personal car.
    Howard
    DUCT TAPE.
    Jan 2005
    Thousands.
    For my TA I have about 250 on each of two laptops.
    Oct 2006
    I would have a couple of hundred easy with my car the amount of changes that I make. Since the RR though I dont keep as many as I should.
    The Tremor at AIR
  1. PCM part numbers
    By killerbee in forum General (Diesel)
    Last Post: April 9th, 2009, 06:32 AM
  2. LC1 AFR output numbers
    By 1bar in forum General
    Last Post: March 23rd, 2009, 09:31 AM
  3. FTC Numbers
    By white2000ta in forum General
    Last Post: January 8th, 2008, 04:19 AM
  4. Table Numbers
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: March 3rd, 2006, 07:21 AM
  5. SD Logging with WB- Numbers do not look right???
    Last Post: July 19th, 2005, 08:25 AM
