Results 1 to 10 of 10
Thread: Will flashscan
    Nov 2004
    Default Will flashscan
    Scan a non-LS1 GM OBD1 car with the newer OBD2 connector?
    Obviously it won't edit, but my dad has a '94 LT1 Corvette, and occasionally we need to ask the ECM whats up. I know Ease will do it, but I really don't want to buy two seperate things if I can help it.
    FlashScan is for OBDII only, specifically it uses the SAE J1850-VPW OBDII protocol.
    EFILive also sells EFILive V4 for use on OBDI vehicles.
    See here for more details:
    http://www.efilive.com/scan_4.html
    The current list of supported vehicles:
    http://www.efilive.com/scan_4_vehicles.html
    Nov 2004
    Blacky -
    I realize its not quite a fair question. But the reason I ask is that there are some variations in the '94 cars. Some definitely had OBDI setups with only two O2 sensors. Others, like my dad's, have the OBDII connector, and 3 O2 sensors and some other differences.
    Would it hurt anything if I just hooked it up and tried it?
    Quote Originally Posted by mgarfias
    Blacky -
    It won't do anything, the OBD-I data stream is TOTALLY different to OBD-II, the Flashscan interface will not even 'see' the OBD-I data stream.
    Blacky -
    My GTS has both OBDI and OBDII (actually all LS1 Commodores do), I plug both scan tools in at different times to scan different things. Each scan tool uses a different interface cable. You won't damage anything, the power/ground pins are still the same. The data pins are different, so as GMPX said, you won't even be able to make a connection when the data protocols do not match.
    Jul 2003
    What do you scan on your Commodore thats OBD1?
    Quote Originally Posted by Renford
    I only use the ALDL data stream for testing EFILive V4. I don't scan anything useful. Everything I need to scan (from the PCM) is available on the OBDII data bus.
    Jul 2003
    Does flashscan support CAN protocol? if not is it something you will be looking at later.
    Richard
    Richard
    The current FlashScan interface does not support CAN.
    The next update/upgrade will include CAN.
    Jul 2003
    EFILIVE V4 is simply awesome!!!!!
    I like it... A LOT!!!!!!
  1. V2 flashscan with LM1
    By Xtnct00WS6 in forum FlashScan V2
    Last Post: June 7th, 2008, 12:50 AM
  2. FlashScan V2.0?
    By bobfo in forum General
    Last Post: October 7th, 2005, 02:20 AM
  3. LC-1 with Flashscan for 98s
    By dlandsvZ28 in forum General
    Last Post: August 24th, 2005, 05:44 AM
