Results 1 to 10 of 17
Thread: new to autoVE tuning
    May 2008
    Default new to autoVE tuning
    Hey guys,
    currently playing around with a vy commodore and doing a maffless tune. Following the autoVE tutorial all the way until we are logging BEN values. I have a couple of questions.
    1. i understand how the EQ ratio is proportional to AFR, but how. Lambda and EQ ratio are slightly out?
    2. if you try to get an EQ ratio of 1.00 +/-.01 all over the BEN graph, doesnt that make top end and under load a tad lean. I do not understand the reason for making the BEN graphs values 1.00 all over the graph?
    3. After data logging, it may be .07 +/- out in some spots, do i keep on pasting and multiplying the BEN table to VE table. THats what i read in the tutorial and if i do, it changes the values too much.
    4. whats the minimum cell count you can use, i dont like the idea of holding th e motor at such high revs. How do you guys map 4000rpm upwards.
    I know i have asked alot, and any help would be greatly apreciated,
    thanks Julian
    using v7 software with v2scan
    Jan 2007
    I'll try to answer some of these...as I understand it.
    1...not sure..sorry. One thing..higher than 1 in EQ means rich (1 being stoich)
    Higher than 14.7 in AFR means lean....14.7 being stoich.
    2. You're not trying to get an EQ of 1 all over the graph. The Ben factor is basically when you're trying to get the commanded fuel to match the actual fuel as measured via a wideband O2 sensor.
    So...if you command 14.7...the WBO2 should read 14.7AFR. This is a BEN factor of 1.0.
    So...by getting all 1's you're just making the logged AFR equal the commanded AFR.
    It doesn't matter whether or not PE is enabled...infact...I believe you should keep it enabled so you don't go lean under higher load.
    If you command an AFR of 12.5 under PE and your WBO2 reads 12.5...it's still a BEN of 1.0.
    3. As you get closer to the 1.0 magic number....you may need to tighten your filters.
    4. Min cell count....I sometimes use 50+ for the cells I hit ALOT.
    For others which I rarely hit....I might only use a cell count of 5-10.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Julian,
    Welcome to the forum...
    EQ = stoich/AFR = 1/Lambda
    Where stoich is defined in B3601, can be 14.63 or 14.68.
    Julian,
    BEN = measured_AFR/commanded_AFR = commanded_EQ/measured_EQ
    BEN is not EQ;
    BEN is the ratio of how close the measured and commanded AFR's or EQ's are
    BEN == 1.00 means they are equal.
    Joe
    To get cell hits above 4000 rpm, set the min cell count lower as Howard said.
    Jan 2005
    Welcome to the forum Julian. Looks like the guys have answered your questions. Please feel free to post up any other questions you may have.
    Jan 2007
    Oh...and I set my commanded to 14.45 where it would normally be 14.63 to ensure no rounding and ending up with trims active.
    Howard
    DUCT TAPE.
    May 2008
    thanks for the help guys. Will play around with it today. im sorry for such stupid qestions. Higher up in the rev range, is it all right to log only like every two cell, and then smooth out the VE table? So it is alright to keep on copying the BEN table to the VE table to try to get closer to one. I will tighten the filters up and try that, because when i did copy and paste it after the second log, it would change the values by .07+/-.
    Cheers Julian.
    Jan 2007
    No such thing as a stupid question. Stupid is to not ask...and blow something up!
    This is what I do...right or wrong...don't know but it seems to work.
    During a log I try to hit as many cells as possible at steady state driving (difficult in built up traffic).
    Sometimes I'll drive down some back roads at really low speed...like barely out of idle and I just try to hit the low Kpa/RPM cells.
    On the freeways I try to hit the higher RPM cells and then push into boost for small amounts of time at different RPM levels. I watch my boost guage (because it's infront of me...laptop is on the passenger seat). I try to make the boost guage needle sit at certain points for as long as possible.
    Once done....I apply my filters so...EXCLUDE the following:
    TPS less than 0.5% (to remove decel)
    TPS varying by more than 5%
    IAT's lower than 40oC (my normal running temps are around 50oC)
    ECT's lower than 68.8oC (normal is around 75 for me in this weather)
    KPA more than 105.5
    I then look at the cell count.
    If it was a new tune...I might do the first run at 10 cells or more (so set empty cells to 10).
    That should get within the ballpark.
    I then remove filters and empty cell countfrom the log and take another look at the raw data.
    I look at the decel cells and if rich I'll do a copy with labels/paste and multiply with labels..then I 'guess' and pull the cell adjustment back a touch. Eg, If I do the paste and a cell changes from 60.0 to 55.0 because it was running rich on decel...I'll then change that to say...57.5. I do this so as to not keep 'overshooting' the mark and going back and forth. I'd rather sneak up on the 'magic 1.0'.
    I then look at area's where I've hit cells in a row and have missed some in between on the same line. I just adjust those 'inbetween' cells along the same lines as the cells either side.
    Then....I run another log...and do it all again. So far....750 plus logs...and still not happy.
    My truck is 'unique' though...and I think I'm just a little OC (never used to be...before EFILive ).
    Hey...anyone else can steer me toward a better way...I'm happy for the constructive criticism.
    Howard
    DUCT TAPE.
    What Howard said: the stupid questions are the ones that were never asked.
  1. autoVe tuning?
    By skneeland in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: November 1st, 2008, 02:20 PM
  2. AutoVE Tuning
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: September 30th, 2006, 12:48 PM
  3. AutoVE Tuning Eval
    By Doc in forum General (Petrol, Gas, Ethanol)
    Last Post: February 7th, 2006, 03:56 PM
  4. Tuning w/o AutoVE
    Last Post: December 5th, 2005, 03:25 PM
  5. AutoVE tuning Help
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2005, 11:55 AM
