Results 1 to 8 of 8
Thread: Strange scanner/Maps issue
    Jan 2007
    Default Strange scanner/Maps issue
    Opened scantool on my laptop at 5am this morning to run a log on the way home from work only to discover all my Maps that I had setup had disappeared completely?
    Any idea why this would happen?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Jan 2005
    Like missing from the hard drive, or not displayed in the scan tool?
    Jan 2007
    Not displayed.
    Ie...I had specific maps setup under each letter (for the past 2 years or so) A-J and they just vanished.
    I had to do the Shift+Cntrl+M and re assign them.
    Howard
    DUCT TAPE.
    Jan 2007
    Well....
    Just did it to me again!
    Flashed the PCM.
    Opened the scantool to do a RAFIG scan.
    No MAP's..all gone!
    Have to go through and reassign all my MAP's again???
    Howard
    DUCT TAPE.
    You can set up a file called xxxxx.mls, where xxxxx is the name of the PID file that you can load. If such a file exists in the PIDs folder then the maps specified in that *.mls file will be loaded (when the mathcing PID file is loaded) instead of the most recently used MAPs from the registry.
    However, I presume you don't have a file with that name in the PIDs folder.
    So I don't know why the maps are not showing up.
    The maps for each map letter are stored in the registry under the setting:
    \\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Map
    EFIlive should write the current set of map file names into the registry when it EFILive is closed. Check that they are configured in there correctly after you close EFILive.
    Paul,
    In the *.mls file, can I specify "subfolder\mapfilename" (I have some map files in subfolders)...?
    Also, in the pids folder I have some pids in subfolders, can I have *.mls files in those subfolders...?
    Joe
    Yes, but the "MAPs" folder name and a \ are prepended to whatever you have in the *.mls file. So ALL maps specified in the *.mls file must reside somewhere underneath the \My Documents\EFILive\V7.5\MAPs folder.
    Jan 2007
    Thanks Paul,
    I'll check it out.
    Howard
    DUCT TAPE.
  1. Strange fuel issue
    By Forcefedperformance in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 24th, 2009, 07:13 PM
  2. Strange RPM issue
    Last Post: August 29th, 2008, 07:25 PM
  3. Strange MAF&MAP tune issue...
    By dc_justin in forum Custom Operating Systems
    Last Post: October 2nd, 2006, 05:45 AM
  4. Strange issue with A/C in P/N
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 25th, 2006, 10:20 AM
  5. Replies: 0
    Last Post: February 6th, 2005, 03:08 PM
