Ok here's a new one...
I hooked my LC-1 up to the V2 via serial connection. Been working fine for 2 days. Today I did a heater calibration and free air calibration on the LC-1 (V2 was hooked up to it at the time) and now the AFR reads between 4:1 and 5:1 when I'm idling at stoich. It reads the same on the V2 and the scan tool on my laptop. Here's the kicker - when I hook the serial connection up to Logworks, it reads perfectly. The V2 is reading the Lambda value correctly, but is somehow converting that to AFR incorrectly. I'm going to try and update to the latest firmware (I did the May 3 update but not the May 6 update) and see if that fixes it. Ideas? I changed NOTHING in the V2....just a heater cal and free air cal of the wideband.
