Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: BB Logging beta update: May 12, 2008
    Default BB Logging beta update: May 12, 2008
    IMPORTANT
    IF YOU HAVE NOT ALREADY DONE SO,
    YOU MUST UPDATE FLASHSCAN'S BOOT BLOCK TO V2.05.08(0426)
    BEFORE
    YOU ATTEMPT TO UPGRADE THE FIRMWARE TO V2.05.16 OR LATER.
    Under no circumstances should you attempt to use boot block V2.05.06 (released March 26, 2008).
    See this link for more info on what is wrong with V2.05.06
    http://forum.efilive.com/showthread.php?t=7804
    Download here: http://download2.efilive.com/Softwar...ay_12_2008.zip (19Mb)
    This download includes and supersedes all previous BBL beta downloads.
    The Readme_First.pdf file included in the zip file has been updated. Please read the first page about new folder names and locations.
    The FlashScan AutoCal V2.5 Release Notes _beta_.pdf file has some important "Known Issues" documented for EFILive_Explorer.exe. Please read them.
    The FlashScan AutoCal V2.5 Quick Reference _beta_.pdf file has been updated with a couple of new menu options and a new hotkey.
    Make sure you update your FlashScan (and/or AutoCal) firmware and boot block using the latest *.ffw files from the \Program Files\EFILive\V8\Firmware folder.
    For those of you waiting for the AutoCal beta test units, they should ship this week.
    Jul 2007
    Hi guys,
    I have one small bug for this release.
    In the ScanTool, under PIDs, there is a new "system" option called "Coditions" that holds the GM.EOPS PID. I know it's getting a bit picky and there is probably some more exciting work to do, but thought I'd let you know anyway.
    Simon.
    Hi guys,
    Simon.
    Please continue to be picky, these things need to be fixed and with my spelling/typing skills I need all the help I can get.
    Jan 2008
    we had just been discussing the transmission description in the scan tool that says LB7/LLY transmission and LBZ/LMM transmission. This description is slightly inaccurate, in that there are certain circumstances in which those descriptions don't apply to the transmission one would desire to log.
    Off the top of my head.
    1. Vortec 8.1L gas engines in Silverados had Allison 5 speeds.
    2. '06 LLY's were equipped with an Allison 6 speed.
    Just a suggestion, maybe change the description to Allison 5 speed and Allison 6 speed instead of the aforementioned misleading descriptions.
    Umm, yes good idea.
    Quote Originally Posted by bballer182 View Post
    Senior Member SV8346's Avatar
    Nov 2007
    ok not sure what the go is here but this is the problem i have just found. In my options.ini file i am logging KR under the LS1. On the V2 it displays KR and registers if there is any knock but if i record the data onto the sd card then view the log on the laptop it says the KR is not selected in the PID selection and hasn't logged it.
    2016 RG Colorado 2.8TD
    Quote Originally Posted by SV8346 View Post
    It should be fine, can you send me the *.tun file please, and I'll see what's wrong (paul@efilive.com). Include a link to this post.
    Try reducing the number of PIDs so that the channel count adds up to 24 or less. I think KR (and probably other PIDs as well) are being dropped because they just don't fit in the 24 channels.
    Hint: The channel count for each PID is shown in square brackets in the files in the \Program files\EFILive\V8\PID Descriptions folder.
    That does make it easier/quicker... thanks Paul...
    It will be quicker and easier and automatic once I get the version 8 GUI front end written.
  1. BB Logging beta update: May 19, 2008
    Last Post: June 11th, 2008, 10:22 AM
  2. BB Logging beta update: May 06, 2008
    Last Post: May 22nd, 2008, 10:57 AM
  3. BB Logging beta update: May 03, 2008
    Last Post: May 5th, 2008, 02:43 PM
  4. BB Logging beta update: April 14, 2008
    Last Post: April 23rd, 2008, 08:46 PM
  5. BB Logging beta update: March 26, 2008
    Last Post: April 6th, 2008, 06:43 AM
