Originally Posted by
swingtan
Hi Guys,
I have another query on these OL fuel tables after talking with Hymey.
B0145, B0147 and B0148 are all multipliers for various conditions and effect the final commanded fuel. In the descriptions, the figures are all multiplied to the values in the tables B0141 to B0144, which works in EQ. These tables still work OK when using AFR's but the "seem" wrong. For example, multipliers greater than 1 will cause a richer mixture. But when working in AFR, a multiplier greater than 1 would result in a leaner mixture.
Is it possible to have these tables converted on the fly, like the others, when changing between EQ / Lambda and AFR? For example, if working with AFRs, the table values in B0145, B0146 and B0147, should be displayed as 1/(EQ multiplier). Does any of this make sense?
Simon.
