Results 1 to 2 of 2
Thread: Do I need a PID to LOG serial data?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Default Do I need a PID to LOG serial data?
    Using SM-AFr and just wired up a MAX3232 ic. Can't figure out how to get SM-AFR to retrieve signal.
    2015 Z06 A8
    I presume that is a PLX device?
    Make sure to select PLX in the FlashScan setup menu. Or when displaying AFR data on FlashScan's LCD screen, use Ctrl+Backspace to scroll through the supported wide band controllers.
    You need to be using the V2.05.17(0512) firmware that ships with the EFILive V7.5.4 BBL Beta software, here:
    http://forum.efilive.com/showthread.php?t=8033
    Then use the PIDs:
    Code:
    EXT.WO2ST1                 F408 SED-16-900   .                External         "External Wideband Sensor State"
    EXT.WO2ST2                 F409 SED-16-900   .                External         "External Wideband Sensor State"
    EXT.WO2LAM1                F40A UNM-16-913   "lambda"         External         "External Wideband Lambda"
    EXT.WO2LAM2                F40B UNM-16-913   "lambda"         External         "External Wideband Lambda"
    EXT.WO2AFR1                F40C UNM-16-914   "AFR"            External         "External Wideband AFR"
    EXT.WO2AFR2                F40D UNM-16-914   "AFR"            External         "External Wideband AFR"
  1. Motec PLM Serial Data to V2
    By RetroAus in forum FlashScan V2
    Last Post: February 6th, 2016, 11:32 AM
  2. BBL & Serial LC-1
    By L31Sleeper in forum FlashScan V2 BB Logging
    Last Post: January 19th, 2010, 11:01 AM
  3. LM1 through the 9 pin serial...
    By rubbersidedown in forum FlashScan V2
    Last Post: August 2nd, 2008, 02:00 AM
  4. Do I need a PID to LOG serial data?
    Last Post: May 15th, 2008, 05:39 AM
  5. WB serial to LT serial?
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: May 12th, 2008, 09:17 AM
