Can someone suggest an easy filter to capture data when in OL and CL? I know I can create a filter based on OL triggers when in CL, but is there a common filter that I can employ whether I am logging in OL or CL?
2015 Z06 A8
Joe:
I would think so much like CL/OL indicator on a dash page. I just don't know how to configure it.
After looking at a dash page, it looks like a value of 4 would indicate OL when using fuelsys A map. Sound right?
2015 Z06 A8
i too would like to know how to filter out CL with my RR.
this way fuel can be added or subtracted in the VE table for wot runs.
but left alone during cruising.
Yes, I just played around with it in the status properties of that pid... it seems:
Code:FUELSYS B, Bank 2 (low byte): 1 = OL 2 = CL 4 = OL-Drive 8 = OL-Fault 16 = CL-Fault FUELSYS A, Bank 1 (high byte, i.e add 256 to each of these): 1 = OL 2 = CL 4 = OL-Drive 8 = OL-Fault 16 = CL-Fault
If you're monitoring FTC#, you can say...
Exclude data frames where FTC# is less than or equal to 19. Then, CL and OL-decel should be excluded.
