Results 1 to 6 of 6
Thread: Scan doesn't find PCM - but everything else works ...
    Lifetime Member Garry's Avatar
    Jun 2006
    Question Scan doesn't find PCM - but everything else works ...
    Title says it - FlashScan connects to V2 just fine, as do Explorer and Tune ... Tune also doesn't have any problems reading PCM information. V2 displays information from the PCM just fine in scan mode, BB scan works ... but Scan fails to retrieve any data from the PCM ...
    Running 7.5.4 w/ Firmware from May 12th ...
    Have I missed changing anything in Flashscan? I have no problems connecting to the PCM w/ FlashScan via V1 ...
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Same problem here, think there's another reply in the BBL forum under the May 12th update.
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Quote Originally Posted by Garry View Post
    Roll back the firmware and it should work again. Its been reported and there is a fix coming. It fails with VPW and cant find the PCM and then flicks over to Flashscan Cable Only as the controller.
    Jun 2006
    OK, tnx ... I thought I read everything in the Update threads, but must have missed that one ... May 9th version works...
    See starting from post #33: showthread.php?t=8033&page=4
    Garry, I get the same results.
  1. It works in VirtualBox!
    By endo in forum EFILive on Linux
    Last Post: August 27th, 2010, 12:06 AM
  2. Scan doesn't work after upgrade
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: June 2nd, 2009, 03:11 PM
  3. Replies: 3
    Last Post: May 16th, 2008, 10:33 PM
  4. Cannot use Scan - Tune works ok
    By John Reed in forum General
    Last Post: February 6th, 2008, 03:15 PM
  5. Let's see if this works...
    By SSpdDmon in forum Gen III V8 Specific
    Last Post: June 26th, 2007, 03:20 PM
