Hi All,
I'm working on an update to the AutoVE tutorial. One aspect that I am including are scripts to perform the needed modifications in addition to the written instructions and pictures.
Here's my first crack at the AutoVE script. Please take a look, test, and let me know if anything looks or works incorrectly.
Thanks in advance, see the following notes:
Code:
;****************************NA AutoVE Imperial Script Starts Here**********************
;This script modifies OS # 12593358 for AutoVE tuning purposes.
; * EQ ratios based on {B3601} = 14.681
; * All fuel parameters set to equivilence ratio (EQ) (EQ={B3601}/AFR)
; * All temperature parameters set in imperial (*F).
;The following parameters and tables are modified:
;{B3313} DFCO Disabled
;{B0701} COT Disabled
;{C2901}, {C2902}, {C2903} MAF fail frequency set to disable MAF meter
;{B4205} Open Loop Enabled
;{B3618} PE Modifier Adjusted
;{B3605} Open loop fuel table adjusted
;{B3801} LTFT Disabled
;{B4108} STFT Idle trims disabled
;{B4206} STFT open loop trims disabled
;{B5914} Low octane timing table overwritten by high octane timing table values
;{C6002} Adjusted DTC's:No MIL for MAF related codes for SD mode
;Auto Only: {E0102} Set auto transmission DTC fault max pressure enablers to not increase pressure in SD mode. ****commented out**** If you wish to perform this, uncomment line 138.
;Auto Only: {E0103} Set auto transmission failsafe enablers to not increase pressure in SD mode. ****commented out**** If you wish to perform this, uncomment line 139.
;Auto Only: {E0104} Set auto transmission DTC fault pressure modifiers to not increase pressure in SD mode. ****commented out**** If you wish to perform this, uncomment line 140.
;ETC Only: {C6101} ETC predicted airflow increased by 25% to prevent DTC P1514. If DTC occurs during tuning, increase in 10% increments until negated.
;{B0101} 15% increase in main VE table, idle areas excluded
;{B0103} 15% increase in backup ve table, idle areas excluded. ***commented out*** If you wish to perform this, uncomment line 190.
;COS Only: {A0008} Open loop ECT commanded fuel multiplier adjusted
;COS Only: {B3647} Commanded fuel vs RPM table adjusted
;{B3636} Vehicle speed lean cruise enable set to max value to disable lean cruise. ***commented out*** If you wish to perform this, uncomment line 200.
;{B0203} Air pump disabled
; __________________________________________________________________________
;****************************NA AutoVE Metric Script Starts Here**********************
; * All temperature parameters set in metric (*C).
;{B0103} 15% increase in backup ve table, idle areas excluded. ***commented out**** If you wish to perform this, uncomment line 190.
Split into metric and imperial versions. It's also been brought to my attention that I should specify this is primarily for naturally aspirated applications. Forced Induction scripts posted in another thread.
