Results 1 to 5 of 5
Thread: Wrong descriptions?????
    Jan 2007
    Default Wrong descriptions?????
    Can someone tell me if I'm missing something here?
    I'm looking for some way to get rid of my lean tip-in issues.
    I found this thread http://forum.efilive.com/showthread....ighlight=B3617
    Which says this:
    The description is wrong in EFILive. It should say:
    When in power enrichment mode this value is added to the commanded fuel EQ Ratio.
    It's never been changed....should it have been?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    It has been noted for the next (or subsequent) update.
    Jan 2007
    Thanks Paul,
    I also sent you an email a week or so ago about another one with the wrong description.
    Howard
    DUCT TAPE.
    My bad, I thought this was the same one.
    To make sure I get them both right, can you please put both in an email and send it to me. I'll make sure they get added to "the list".
    Jan 2007
    Sure thing Paul.
    Thanks for all your hard work.
    Howard
    DUCT TAPE.
  1. After the newest update can anyone else not get PID descriptions
    By Jasondt2001 in forum Black Box Logging
    Last Post: January 2nd, 2010, 06:43 PM
  2. Error codes and descriptions
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: October 26th, 2009, 12:29 PM
  3. Quick question about PID Descriptions...
    By JR_VETTE in forum FlashScan V2 BB Logging
    Last Post: March 31st, 2008, 08:52 AM
  4. v7.2.3 Knock Parameter descriptions
    By jsttry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 6th, 2005, 01:12 AM
