Results 1 to 6 of 6
Thread: Help, Turned off cruise control
    Jan 2007
    Default Help, Turned off cruise control
    Somehow in my bumbling key punching I have lost my cruise control. I am not sure if it has to do with tuning or if something is wrong with the truck. Is there a place to turn it on and off with EFI live?
    Oct 2005
    Not really, the only table I am aware of is B0852 max. injected fuel in cruise mode.
    2005 RCSB 2500HD GMC Sierra DURAMAX LLY
    1955 Chevy Truck 1st series, being restored
    2002 Mercedes C270 CDI
    Before flashing, did you save a copy of the ECM's tune...?
    Jan 2007
    Just to update the thread in case it happens to anyone else, I had loaded a manual trans file into my auto truck so the ecm and tcm were not communicating. Amazingly the truck ran and shifted fine other than the cruise problem.
    General rule of thumb, ALWAYS use the .tun file read from the truck, switching tunes from one truck to another tends to result in tears.
    Oct 2010
    I have this problem right now with a customers truck... I Downloaded A modified TCM tune off of diesel place and forgot to save his stock tcm file, sooo now I dont have cruise control because i understand I dont have the right OS, so I am going to try sucking a TCM file out of two other 05 LLYs and try those in it, any other Ideas on how I can fix this issue???
  1. Cruise Control Surging
    By ViciousKnid in forum Gen III V8 Specific
    Last Post: February 9th, 2010, 04:55 AM
  2. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 08:42 PM
  3. Tranny Swap Now No Cruise Control In 6th Gear???
    By Southern Speed in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2007, 02:07 PM
  4. What causes surgin/cruise control?
    By pkincy in forum General (Petrol, Gas, Ethanol)
    Last Post: January 29th, 2006, 12:57 PM
  5. Cruise Control Effect
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: December 27th, 2005, 07:15 AM
