Results 1 to 3 of 3
Thread: Unable to read DTC's
    Dec 2007
    Default Unable to read DTC's
    I have a check engine light on my 2008 GMC Sierra Duramax. I'm using the latest firmware and software. EFILive says there are no DTC's. I cannot connect with my Actron. Went to Autozone tonight and their scanner would not connect either. Onstar says there is a fuel delivery code, see dealer within one day. EFILive will clear the code (light goes off) but it comes back as soon as started. Any ideas what to try?
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default Hmmmm.....
    Quote Originally Posted by rdaniels View Post
    Hmmmmmmm... I tried to read codes from an 07 Duramx today and nothing happened....
    I wonder if it's the same thing???
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Try the update that will be made available Mon 19th May (US time) in this thread:
    http://forum.efilive.com/forumdisplay.php?f=69
    Once you have that update installed, if the code is still not displayed correctly, select the FlashScan option that saves all diagnostics and copy the saved DTC file from FlashSCan to your PC using EFILive_Explorer. Then email the DTC file to me at paul@efilive.com
    After saving the diagnostics, please also save the trace file and copy that to the PC using EFILive_Explorer as well and email it to me.
    To save the Trace file: F2 Scan Tool -> F3 Scan Options -> F1 Save Trace File.
  1. E38 unable to program
    By HTMtrSprt in forum E37, E38 & E67 PFI ECM's
    Last Post: April 29th, 2010, 12:35 AM
  2. Unable to flash Custom OS into PCM
    By Robbie The Wrench in forum Gen III V8 Specific
    Last Post: February 23rd, 2009, 03:00 AM
  3. Unable to see GM PIDs
    By Babydeuce in forum General
    Last Post: May 28th, 2008, 10:04 AM
  4. unable to clear dtc's
    By vdawg4 in forum EFILive V4
    Last Post: January 28th, 2008, 03:39 PM
  5. Unable to log
    By Telco in forum FlashScan V2
    Last Post: December 7th, 2007, 02:39 AM
