Results 1 to 2 of 2
Thread: LS2 472bhp out of the crate (engine dyno)
    Feb 2007
    Default LS2 472bhp out of the crate (engine dyno)
    Interesting article regarding the LS2, 472BHP with race headers on an engine dyno. Only 400BHP in the vechicle, I suspect the air intake to be big factor in the difference, in my logs i'm seeing 92-93kPa @ 6400rpm at WOT when BARO = 102kPa.
    I note from the article 29 degrees of advance dialed in with ported heads and fast intake.
    http://www.popularhotrodding.com/tec...ion/index.html
    "As you can see, the AFR heads and FAST intake really helped the LS2 inhale. With a gain of 41 hp and an increase in torque of 39 lb-ft, only the limitations of the stock cam were holding back the engine. Still, for such a mild cam, 503 hp and 489 lb-ft of torque isn't too shabby. Timing was set at 29 degrees"
    Apr 2008
    Brother that's awesome! Can't wait to start bringing the GTO into her own state of tune!
    2005 Chev 3500 DRW D/A, Banks 6 Shooter PDA, Banks CAI and 4" exh.
    2006 GTO Diablo Sport tune
  1. Engine Trans Dyno Tuning Questions!
    By TBMSport in forum General (Petrol, Gas, Ethanol)
    Last Post: November 14th, 2009, 11:37 AM
  2. GM LS Crate Engine Tuning
    By TurboCamaro in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2009, 03:30 PM
  3. LBZ on an Engine Dyno
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 25th, 2008, 03:32 AM
  4. went to the dyno look at my log
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 18th, 2007, 03:22 PM
  5. Dyno success on Dynolog Dyno
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 1st, 2006, 11:31 PM
