Tried the JAW wide-band and get "Controller Not Found" message .
Made sure cable is correct and that it was selected in V2 as well (LC-1 works and just changed controller to JAW) .
The serial on the JAW is working correctly (serial 2 , 3 , 5) , because I can use it's software and it registers correct data .
This is how I have the Serial to RJ25 (12) cable pins assigned :
DB9 RJ25 (12)
5 > 5
3 > 1 Switched rather than using Null Modem cable .
2 > 2
