Results 1 to 7 of 7
Thread: Error on LMM
    Junior Member jpgmtech's Avatar
    Mar 2007
    Default Error on LMM
    Getting an error trying to read an LMM:
    Cannot merge calibrations with operating system file:
    C:\Program Files\EFILive\V7.5\Configuration\M97.bin
    I just installed EFILive on a new laptop, and now I have a paying customer standing here waiting for his DPF removal program... of course this has to happen now.
    I searched my hard drive, and I cannot find any files by the name of M97.bin
    Thanks,
    BTW using version 7.5.3 full install.
    Mar 2007
    Incase you didn't get the message, he has the newest operating system, which sucks for both of you......... because if you do the DPF delete, he will have to ride around with your V2 in his pocket to clear the codes.
    Don't ask me how I know. Shnizzle
    Mar 2007
    Unfortunately, I didn't get the memo...
    Used a work-around for this as he travelled 6 hours to get to the shop! I pulled an ECM from another used 2007 truck that we had on the lot that had not been updated, and set that up in his truck. Works great for him.
    Normally the program says "calibration not supported" when this occurs, not "missing file" or "range error" or something like that.
    At any rate, I will be quizing customers on this before I set up an appointment until support is released...
    Mar 2007
    I am in the same boat.
    Jul 2008
    hey guys, i've just run accross this same error in an 2007.5 LMM with the latest programming as of 7/7/08.
    I'm needing to know how to resolve this issue. I'm getting the exact same error message, as shown in the screen shot below.
    Any information would be appreciated.
    Thanks in advance.
    Easiest fix is to download the latest software from here -
    http://www.efilive.com/download.aspx
    EFILive V7.5.4 Release
    Jul 2008
    downloading now, will install and re-test tomarrow evening.
    Thank you for the quick responce and i'll update with my progress.
    Tony
  1. Error BBR 98 PCM ... again
    By Ninety8C5 in forum FlashScan V2 BB Logging
    Last Post: March 5th, 2010, 09:24 AM
  2. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 02:22 PM
  3. RAM Error
    By bobo in forum FlashScan V2 BB Logging
    Last Post: February 26th, 2008, 10:59 AM
