Results 1 to 10 of 12
Thread: PID TRQTRANS, good bad or ugly?
    Jul 2005
    Default PID TRQTRANS, good bad or ugly?
    THe PID "Delivered Torque" (GM.TRQTRANS)
    1. Does any one know what is used to measure it and how accurate is it?
    2. Does it have a max?
    3. Is it usefull for for judging how good a mod works?
    4. Has anyone logged this PID on a dyno run and compared the results?
    Junior Member daveb's Avatar
    Feb 2005
    I am also interested in this. I have been measuring these values which appear to be half what I would expect.
    The max I see is 300 Nm on a car with 300 rwkw. The FW KW which is based on engine torque does not get above 200KW.
    Has anyone else seen this?
    Jul 2005
    I don't think you are looking at the same PID I am. What PID's are you looking at?
    I know the "POWER_RW" PID is a CALC PID and it would be low because it does not account for any aero drag. It is a calculation based on acceleration and mass.
    The CALC.POWER_RW will NEVER be accurate (except by chance) on a dyno. It measures acceleration and, from a known vehicle mass, can calculate force and then power. A dyno does not simulate (nor even attempt to) the vehicle's correct mass/acceleration.
    Default Re: PID TRQTRANS, good bad or ugly?
    Quote Originally Posted by bobfo
    That PID measures the calculated engine torque minus the torque loss from spark retard.
    The torque loss from spark retard is determined by the calibration {B1902}.
    The calculated engine torque is determined by the PCM from airflow, rpm and internal torque tables.
    It appears that GM calibrated (or computer modelled/estimated) the torque output of the engine under various air flows, fuel ratios and rpms and stored those torque values into a table in the PCM. The PCM simply looks up the torque values in those tables based on the current airflow, fuel ratio and rpm and reports the "calculated/estimated" torque after filtering, smoothing, adjusting for spark retard etc.
    Once you have modified your engine, the PCM's ability to accurately report the engine's torque output is compromised*. And therefor the value of that PID is also compromised.
    *Unless you recalibrate those internal torque tables - but to do that you'd need an engine dyno. Which defeats the purpose of having an accurate PCM calculated torque value - which does not and can not exist.
    Only in so far as the PCMs internal calculations have a max.
    In my opinion, no (but I am not a tuner).
    Not that I know of.
    I've heard this PID can relplace a WBO2 :lol: :lol: :lol: :lol:
    Quote Originally Posted by GMPX
    And I've heard you don't need a dyno either 8) 8)
    Feb 2005
    BOBFO - I have been measuring the delivered engine torque and the trans torque. BTW the flywheel power uses the delvered engine torque.
    Blacky - I thought there was a torque sensor measuring turning force on the drive shaft. Is this not the case? Since I have an auto torque values effect shifts and I have been keen to understand what the PCM thinks the torque is as desired shift times and trans pressure is calibrated using torque values.
    I do admit it is pretty good as I have programmed the VSS changes how I like, but I do not understand when the torque values are used to determine shifts (ie D1108-D1110 & D0701-D0703).
    Thanks,
    Oct 2003
    Will you guys quit picking on John Rovner, he's smarter than all of us put together you know.... :lol:
    Sep 2003
    You guys are too much. :wink: :wink: :wink: :wink:
    Larry - HumpinSS
  1. Timing and Knock. Ugly stuff
    By kwhiteside in forum Gen III V8 Specific
    Last Post: July 19th, 2009, 06:16 AM
  2. The Good, The Bad, And The Ugly...
    By 2002_z28_six_speed in forum FlashScan V2 BB Logging
    Last Post: May 8th, 2008, 01:46 PM
  3. Good afr?
    By Powerhouse in forum Gen III V8 Specific
    Last Post: July 28th, 2007, 02:09 PM
  4. At idle OL AFR good, CL 16 AFR
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 23rd, 2006, 11:40 AM
  5. PID TRQTRANS, good bad or ugly?
    By bobfo in forum General
    Last Post: August 14th, 2005, 01:04 PM
