Thread: FlashScan to LC-1 Serial Cable Diagram
    Default FlashScan to LC-1 and LM-1 Serial Cable Diagrams
    Diagram showing the various cables and pin-outs required to connect FlashScan to an Innovate LC-1 or LM-1 Wide band controller.
    For those that want a simple cable solution, you can wire up an RJ12 plug directly to the 3 pin jack as follows:
    Code:
    RJ12    Jack
     1 <---> 1 (tip)
     2 <---> 2 (middle)
     5 <---> 3 (base)
ID:	3333   Click image for larger version.
    The null modem connector can be purchased here:
    http://www.sfcable.com/cable/p/30D1-C1-S.html
    If you want to make your own male-male null modem cable, see images below.
    (Ok, so the soldering could be better, I'm just a programmer. Beware the programmer wielding a soldering iron...)
ID:	3334   Click image for larger version.
ID:	3335   Click image for larger version.
    For those of you that can't locate your LC-1, LM-1 and/or FlashScan serial cables, this is what they look like.
    The names of the pins are as shown in the 3rd column:
    Code:
      RJ12         Jack         Name
      1  <--->  1 (tip)       Tx Data
      2  <--->  2 (middle)    Rx Data
      5  <--->  3 (base)      Ground
    Default Innovate LC-1 and LM-1
    Innovate LC-1 and LM-1.
Name:	LC1 cable V2.jpg
ID:	4047   Click image for larger version.
Name:	LM1 DIN to 9pin.png
    Also see here: showthread.php?t=9340
  1. Flashscan to LM-2 Serial Cable
    By TAQuickness in forum FlashScan V2 BB Logging
    Last Post: May 2nd, 2016, 10:36 AM
  2. serial port cable that goes to v2
    By articSS in forum FlashScan V2
    Last Post: August 19th, 2014, 12:57 PM
  3. Tried making own Serial Wideband Cable, HELP!!
    By edwardzracing in forum FlashScan V2
    Last Post: March 18th, 2009, 04:54 AM
  4. FlashScan V2 OBDII Cable
    By minytrker in forum Purchase and Shipping
    Last Post: November 25th, 2008, 03:37 AM
  5. fjo serial cable questions..please help
    By articSS in forum Black Box Logging
    Last Post: October 28th, 2008, 03:05 PM
