Results 1 to 8 of 8
Thread: newbie
    May 2008
    Default newbie
    So what do I get with a new unit? how many dmaxes can I tune? (My dad has one also) can I tune anything in the transmission (allison)? and can I get make a custom message in the DIC like the ones show in someones avatar on here that says TUNED WITH EFILIVE? that would be awesome! I'm gonna buy one of these cause I have been reading alot over the last year or so and have heard of some guys make awesome power and also making some good fuel mileage tunes, also this DSP5 how does this work? does that mean I can switch between 5 different power levels on the fly? I see they are not that expensive for the switch and wiring. also who do I call to speak in person with someone about this, Thankyou in advance guys, Lee
    Dec 2007
    you will git the the unit, obdII cable, usb cable, CD, a cuple header blocks and 2 vicheal licenses which will allow you to tune 2 trucks ( 2 ECM's and 2 TCMs)
    from what i understand you can not change your DIC with custom messages
    for the DSP5 you load a custom operating system along with the parameters for the 5 tunes
    and you switch on the fly (not available for the LBZ motor)
    there are several good vender's around that offer a race or tow tune or bonis items along with your purchase
    Sep 2006
    The only EFI Live vendors that I have dealt with are-
    McRat Racing 951-270-0808, Kat McSwain
    SoCal Diesel 661-775-5620, Guy Tripp
    Both have excellent customer service and can get you started with a tune...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Feb 2006
    You can make custom messages for the DIC, but they only show up during EFI_Live operations. They won't show while you are driving or during some other event.
    Al
    Quote Originally Posted by catman3126 View Post
    If you want to try out the DSP5 switchable tunes without wiring a switch, we are close to releasing an update to FlashScan that allows you to select which tune you want to run directly from a menu on the FlashScan screen.
    Obviously a switch is faster far more convenient than connecting up FlashScan. But it is a good way to get started with DSP5 without worrying about wiring a switch.
    May 2008
    can I send my ecm to you and have it programmed and a dsp5 switch put in? or do I need to get the efi Live for myself? also it is possible to have lets say a 50 horse tune and 200 horse tune and a few others in between?
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
    EFILive will not program it but if you send it to a tuner they can usually install DSP5 and a switch for you. This will cost you some money of course, but you wouldnt have to buy EFILive.
    EFILive Distributor Trippin's Avatar
    May 2004
    I'd be happy to tune your ECM for you and supply you with a DSP5 switch.
    I have a 250hp tune and then we can progress down to a tow tune using the DSP5 switch.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
  1. Hello Newbie
    By 001FAZ in forum Lounge
    Last Post: March 12th, 2009, 03:18 AM
  2. Newbie???'s
    By bdr2008 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 11th, 2008, 04:46 AM
  3. Newbie
    By larshep in forum Gen III V8 Specific
    Last Post: November 15th, 2007, 06:59 AM
  4. Newbie
    By Pn2r in forum General
    Last Post: March 17th, 2007, 06:24 PM
  5. Newbie needs big help bad
    By LowETz in forum General (Petrol, Gas, Ethanol)
    Last Post: September 10th, 2006, 11:22 AM
