i want to add the reluctor wheel and cam sensor to my lt1 and use a ls1 computer in it.
i think it should work the main concern is the firing order. i realize that i can just swap the coil wires and injector wires in the harness.
doing this will throw off fueling because when it adds fuel to one bank it will only add to 3 Cly and 1 on the other bank.
also does anyone have information on the 24x reluctor wheel? it look like it outputs a pattern of long pulses and shorter pulses. has anyone mapped this pattern relative to tdc?
also the where relive to tdc does the cam sensor go from low to high?
