Originally Posted by
Biggsy
Got a problem with my car that has always been there since I bought it but haven't bothered to try and fix till now.
Car: VY SS LS1 M6, Stock apart from tune.
Problem:
When in idle, motor has a miss/stumble every few seconds. It doesn't really show in a scan but you sure can feel it.
What I have tried (Not all because of problem):
New Spark Plugs
New Leads
New Coils
New Intake/exhaust gaskets
Std tune, Mod tune, mod tune mafless.
New Battery
New PCM
Checked Earths
Checked for vacuum leaks
Run a cylinder balance check and all are pretty close to each other
Compression check - Good
None of the above made a difference.
If I load the car up, eg A/c on high beams etc, it smooths out the idle a little but nothing to write home about.
Car cruises and accelerates without issue.
The only way I can make it smooth, is to use Bi-Di conrols in the scan tool and command 12.5:1, this makes it idle almost perfect. Wide Band O2 proves it is 12.5:1.
It has me baffled
The only other thing I can think of is maybe blocked injector/s, but I don't want to buy a set and find they are not the problem.
Car has 80,000kms on the clock and has had every service done on time.
Anyone have any ideas?
