Results 1 to 10 of 14
Thread: Vista install ???
    Aug 2007
    Default Vista install ???
    I am trying to install the usb driver But the directions on my install cd are for xp and I am computer challenged. Should I try an online download. My old laptop with XP went right by the instructions. Any help would be great. THANKS, Rodney
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    See if any of these links help (see the last one in particular):
    Aug 2007
    Thanks Joecar,
    I can't view the last one tho...
    http://forum.efilive.com/showthread....8043#post68043 and this one won't allow me to view it.
    http://forum.efilive.com/showthread.php?p=68043
    Aug 2007
    Found the link Off ls1 tech and it worked. Can't seem to clean old drivers to get a fresh start. What is FTClean...??? I can't find that program.
    Forehead is bleeding now
    Default From the link that you couldn't get to:
    How to uninstall the USB drivers if Vista fails to install them correctly.
    1. Disconnect FlashScan.
    2. Run the FTClean program (that removes the driver files from the hard drive).
    3. Reconnect FlashScan
    4. Right click on Computer in the Windows Start menu, select Properties.
    5. Click on the Device manager link at the top left of the window.
    6. Locate the FlashScan device - it may be under "Other Devices" or "Universal Serial Bus controllers".
    7. Right click and select uninstall (that tells Vista it needs to be re-installed next time it is plugged in).
    8. Disconnect FlashScan
    9. Close down the Device Manager window
    10. Close the Control Panel->System window.
    11. Reconnect FlashScan - Vista should restart the driver install wizard from scratch.
    Make sure you are using FlashScan's latest signed drivers. Available here:
    http://www.efilive.com/download.aspx#downloads4
    Aug 2007
    It comes up fine now. Don't know why... I have way more questions than answers. THANK YOU SO MUCH for helping!!!
    Aug 2007
    Can't get this to work ,It says, Could not find FTDI uninstaller program FTDIUNIN.exe Please make sure FTDIUNIN.exe exists in the same directory as this program."
    Best I can tell, it is. They both show up when I click on the icon om my desktop.
  1. 64 Bit Vista
    By Yellow05C6 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 25th, 2009, 01:10 PM
  2. Install help please...vista...run as administrator..cant open calc_pids.txt
    By skippy in forum General (Petrol, Gas, Ethanol)
    Last Post: February 4th, 2009, 09:12 AM
  3. Getting use to VIsta
    By Chevy366 in forum Lounge
    Last Post: October 28th, 2008, 04:00 AM
  4. How do I install the drivers for my V2 on Vista?
    By AustinL911A in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2007, 01:39 PM
