Results 1 to 8 of 8
Thread: {B4105} how do i link this table?
    Nov 2006
    Default {B4105} how do i link this table?
    there doesn`t seem to be any PIDs associated with this table.
    i am trying to make changes to my cal_link to update it with RTACS,
    to rid myself of the slight richness i get in closed loop.
    First off, in cal_link.txt for B4107, it appears you should replace GM.DYNCYLAIR_DMA with GM.DYNAIR or GM.MAF or SAE.MAF since the units should be g/s and not g/cyl:
    Quote Originally Posted by cal_link.txt
    B4107.ROW=GM.DYNAIR,CALC.CYLAIR
    Then, take the values of B4107 and using the lookup() function make a calc pid that maps GM.DYNAIR to CALC.CLMODE (you can stop where the CL mode levels out at 64...):
    Quote Originally Posted by calc_pids.txt
    *CLC-00-200
    None 0 64 0.0 "lookup({GM.DYNAIR}, 0,0, 4,4, 8,12, 12,30, 16,36, 20,40, 24,44, 28,50, 32,54, 36,64)"
    CALC.CLMODE F200 CLC-00-200 None Loop "Closed Loop Mode"
    And then CALC.CLMODE becomes the link to B4105:
    ; O2 switch point
    B4105.ROW=CALC.CLMODE
    The lookup() function is explained in the scantool user manual.
    Nov 2006
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Thanks alot joe. I was thinking it would be great to have fuctions for use in calculated PIDs and was going to ask. This is great, page 94 of the manual. Very cool
    Jez
    Nov 2006
    i have been looking into this and,
    i have found that i can not set the look up value exactly the same as {B4107}
    if you keep going so far an error will occur.
    this
    *CLC-00-200
    is not how {B4107} is in my OS.
    is there a limit to the text that can be inserted into the calc.pids.text?
    or should i change {B4107}.
    also this only tracks up and down, how do i track bank1 and bank2?
    Nov 2006
    this
    *CLC-00-200
    i get this.......
    Closed Loop Mode {CALC.CLMODE}
    Expression:
    = lookup({GM.DYNAIR}, 0,0, 4,4, 8,12, 12,30, 16,36, 20,40, 24,44, 28,50, 32,54, 36,54 40,54 44,54 48,54 53,54 56,56 60,64)
    is NOT valid because:
    Syntax error: "4", position 86.
    PID value cannot be determined because
    the following error would occur:
    Expression not valid: Syntax error: "4", position 86.
    .........when i match the "look up" values to what the table shows.
    how do i match it properly?
    is the calc.pid string value limited?
    is this why the error occurs?
    Oct 2006
    Try adding in the appropriate commas. you started leaving them out.
    Nov 2006
    Quote Originally Posted by ds8 View Post
    LOL
    thanks.
  1. 2 LC1's via serial link?
    By Neptune in forum Black Box Logging
    Last Post: June 18th, 2008, 09:27 AM
  2. Link to MAP
    By TAQuickness in forum General
    Last Post: September 8th, 2006, 05:07 AM
  3. i need a link
    By NviouSS in forum General (Petrol, Gas, Ethanol)
    Last Post: October 13th, 2005, 10:52 PM
  4. VAT Re-link
    Last Post: July 13th, 2005, 10:08 AM
