Why can't I log spark knock on 05 E40 VETTES????
Hey Guys..... I'm having a problem.... When using o/s #12613186 which is found in some 05 E40 vettes, I can not log Knock Retard. It just dosen't work and usually fills the screen with stupid numbers that are like in the teens and twenties.....
I've been having this problem for over a year now......
No matter what pids I select or what I chose to use as KR data, NOTHING WORKS....
The only solution I have found is to use o/s #02598983. All I do is change the o/s and it works perfectly just like all other ls1/ls2 pids normally do even using the exact same pid and map sets.
While this gets me by, it has caused me some problems and I'd just prefer to be able to log KR no matter what o/s I use......
Is anyone else having the same problem?????
Chuck CoW
