Results 1 to 6 of 6
Thread: 07 Cobalt SS IFR wierdness????
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Default 07 Cobalt SS IFR wierdness????
    Ok, So this guy comes in with a Cobalt SS today and it's running like shit.....
    I tuned him several months ago and all was good....
    I discover he decided to replace the 42lbhr stock injectors with 60's and an injector harness change....WITHOUT TELLING ME!
    So, not a big deal to just re-scale the IFR table....BUT>>>>>
    When converting the IFR table to LBHR from grams, EFI LIVE imposes limits of 0-1.05 for the LBS/HR of the injector table.
    WTF? How do I deal with this??? None of the #'s make sense....All I did for now was scale the IFR table up by 30% to make it better, but when doing so...I noticed that the right third of the IFR graph MAXXED OUT and the sloped line of IFR went flat at the top.
    Why isn't the IFR table looking normal like other type cals????
    Any thoughts???
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Chuck,
    There might be a upper hard limit on the IFR that you have exceeded.
    Ross the boss is the one to answer that question.
    If your stuck on it, lower fuel pressure a little and this will act like the injectors are a little smaller then what they are and bring you back to workable limits that you have.
    Cheers
    Mick
    Rev it up, Drop the clutch, See what happens?
    Feb 2006
    Default The problem is.........
    Quote Originally Posted by MICK View Post
    Chuck,
    Cheers
    Mick
    The problem is...... I've changed the IFR table to show LBS/HR and and the upper limit is "2" in EFI LIVE....
    WTF?
    Chuck Cow
    Chuck, I forwarded the link to Paul, I set all the tables up in Metric and it's fine in that mode. I believe the software does the conversion, shoot him a PM about it.
    Junior Member dennisscars's Avatar
    Feb 2008
    Was there a solution for this? I'm having the same problems with 60's with an upper limit of 1.0582 lbs/min or 7.9999 g/sec.
    Quote Originally Posted by dennisscars View Post
    7.9999 g/sec.
    That is the mathematical limit in that PCM, you can't go higher, same issue on the E40, E38 and E67.
    7.9999 g/sec = $FFFF , not much more we can do.
  1. Cobalt rental car
    By cmitchell17 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 21st, 2010, 11:25 AM
  2. LC-1 Wierdness
    By willn in forum General
    Last Post: October 21st, 2009, 03:54 AM
  3. LC-1 Wierdness
    Last Post: September 10th, 2009, 02:22 PM
  4. Support for 06 Cobalt ss/sc 2.0L
    By stkshkr in forum E37, E38 & E67 PFI ECM's
    Last Post: June 12th, 2008, 03:38 PM
  5. Cobalt .cal files
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: December 23rd, 2007, 05:53 PM
