Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Thread: EFILive 7.3 pre-release software is now available
    Default EFILive 7.3 pre-release software is now available
    Download the latest EFILive V7.3 pre-release software here:
    http://www.efilive.com/downloads/downloads_730.html
    A complete CD-based software installation package will be available soon.
    Please post any issues in this thread.
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    It is either my imagination or the software is much faster at processing user input and displaying graphs, etc. Probably not my imagination...
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Jun 2003
    I noticed that also
    Still trying to figure out how gm stuffed all this stuff into less then 1mb
    Sep 2003
    Woot the idle trim pids were added in this release and i have allready tested it out and used it
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Oct 2003
    Quote Originally Posted by Dirk Diggler
    Thanks for the hint . I was going to wait till later......now I'll do it now. Suspense eats at me! :lol:
    In the scanner? What are they named? I can't find them.
    joe
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Yes in the scanner, they are under "Idle". Also, if you click more info on them it will give you a nice description along with the field in Live they correspond to.
    Oct 2003
    How did it go, Dirk?
    Looks like we scan all idle airflow determinants and the various contributions!!
    My son said kiddingly, " you guys have too many parameters, you need a slide bar with "Good" at one end and "Best" at the other end." I laughed then...but.......EFILive is making tuning a heck of a lot easier ( I don't think I'd like the slide bar).
    joel
    Oct 2003
    Quote Originally Posted by jfpilla
    joe
    They're " IAC_xxx_DMA" pids, Joe.
    Long Term Correction In Gear AC Off
    Short Term Correction In Gear AC Off etc.
    joel
    Not all PCM's idle DMA PIDs have been configured yet. Some PCMs may still show them as unsupported.
    Ross is working on adding in the rest of the PIDs over the next few days. So if your PCM shows some or all idle PIDs as unsupported just wait for the next update for them to be available.
  1. Software issues with build 99 pre release...
    Last Post: January 18th, 2010, 04:25 AM
  2. Replies: 22
    Last Post: January 8th, 2007, 02:15 PM
  3. EFILive 7.3 pre-release software has been updated - again
    Last Post: August 24th, 2005, 09:44 AM
