And...you're doing an awesome job of it.I'm just trying to help out
You're right. I reckon I've read every thread in the forums looking for info...alot of it seems to boil down to trial and error.
I prefer your method.
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Aaron
'03 Z06 Corvette - The normal stuff...
EFI-101, EFI Advanced, EFILive-101
EFI University Evangelist
I don't know where he found it, but I tested the "+" and it works.
In any case, please check out this RTACS example. I think its not recognizing the .RRR function for whatever reason. To name a few, I am logging RPM and COMMANDED FUEL. The CALC.PEMULT I created works great and does what I expected, its just not getting applied.
I turned Accuracy to 0, coarse and fine to 1000 to test and even to 1.
Any idea why it won't change the lambda values? Also, even with "all" tps values, it still doesn't matter.
07 Silverado DMax Classic
Ok, I think I figured it out. After playing w/the cell lock buttons, the system seemed to come to life.
More real time testing tommorrow...
