Results 1 to 6 of 6
Thread: Do I need to do a VAT Relink ???
    Lifetime Member Ninety8C5's Avatar
    Sep 2003
    Default Do I need to do a VAT Relink ???
    I had a spare PCM fixed (previously fried) for my car. I can read the PCM (with bench harness) and it has the correct OS, tune and VIN for my car. When I tried to use it yesterday, it would not play nice with the other controllers. I got reduced engine power, service traction control and ABS messages. I could not connect to the PCM wth the Tune Tool with the PCM in the car.
    If I enable a VAT relink will that let this PCM talk to the other controllers or is there something else I need to do?
    TIA
    Sep 2003
    Question
    Does anybody have any idea howto solve this problem ?
    On a 98 C5...?
    I can't find any diagrams for this...
    To be able to do a VAT relink, the PCM must already be able to communicate with the BCM.
    Sep 2003
    Yes, a 98 C5.
    My thought, which is probably flawed, was to enable the VAT relink with a bench harness. Then unplug the power and put the PCM back into the car.
    Hopefully when the power was restored the PCM would talk to the BCM.
    Might work, no chance in hell or any other suggestion to get the PCM to play nice with the other modules?
    Sep 2003
    Quote Originally Posted by Ninety8C5 View Post
    I just re-read page 85 Security/VAT relink in the Tune document and it sounds just like my plan.
    As soon as I feel better, I guess I will try it.
    Quote Originally Posted by tunetool user manual, page 85
    When you click on the [VAT relink] button, EFILive instructs the PCM to set a flag that will cause it to re-link to any BCM (that it can “see”) when the ignition is next switched on.
    Let us know...
  1. Is a licence needed to do a Vat Relink
    By Eric in forum Gen III V8 Specific
    Last Post: August 19th, 2009, 10:23 AM
  2. VATS relink with scan only?
    By mr.prick in forum FlashScan V1
    Last Post: July 9th, 2009, 11:58 AM
  3. VAT Relink
    By Biggsy in forum Gen III V8 Specific
    Last Post: October 10th, 2007, 09:40 PM
  4. Change Vin # and VAT relink
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 23rd, 2007, 01:14 PM
