Results 1 to 10 of 11
Thread: KR and VE issues
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default KR and VE issues
    Logs from today
    KR trouble...this is NA, did not do this last year and I did not mess with the timing any.
    AFR
    BEN's
    Doing the BEN's correction makes no sense 400 rpm, and more Air than 800 RPM?
    Suggestions?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Jul 2006
    LIL help?
    Maine USA
    Jim,
    I think above MAP 80 kPa that AFR 14+ is too lean...
    Your rpm is 1200-1600 and you're opening the throttle (engine load is increasing)... it needs more fuel... richen the AFR in B3647, or in B3618 if you use PE (make sure PE enables before entering that MAP range).
    Joe
    Jul 2006
    Thanks Joe,
    3647 for those fields are set for 11.95, I do not think it is using that table as commanded is showing 14.63
    My PE enable is set for 62% and I am easing into that speed below the PE enable?
    From looking at the logs commanded is 14.63 TP varies from 7% to 43% for those areas...
    So how to fix??? Set 3616 PE to 35% or so?
    Maine USA
    Oct 2007
    jim are u running a maf ??
    01 Z06, 4L60E CONVERSION, L92/L76 TOP END, 72# LS3 INJECTORS (THANKS FIC), DRY NITROUS, COS5
    Jul 2006
    Quote Originally Posted by WHYTRYZ06 View Post
    Yes I am.
    Maine USA
    Are your BEN's close to 1.00...?
    Jul 2006
    Log attached
    Maine USA
    Jim,
    Yes, set B3616 lower (try some different values, see what you like) and check that the PE MAP enable threshold is 80 kPa or lower... you may have to tweak B3618 till you get your measured AFR where you want it (and to prevent that knock).
    [I can't view your tun on this PC... I'll view it tonite]
    Joe
    Jul 2006
    Jim,
    Joe
    I cannot find where PE MAP enable is...found one if MAP is 15 or higher PE can be enabled, but nothing like enable PE w/ MAP 80-100...I am running a 02 OS for COS5
    Maine USA
  1. What have the issues been with LMM'S?
    Last Post: September 22nd, 2009, 02:06 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 15th, 2009, 12:07 AM
  3. 2 bar E38 issues
    By XLR8NSS in forum E37, E38 & E67 PFI ECM's
    Last Post: May 1st, 2009, 03:51 AM
  4. KR log issues
    Last Post: October 3rd, 2008, 11:58 AM
  5. Ok some serious issues
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 05:45 AM
